I did it! Now I can't get enough!
Old Mar 6, 2007 | 04:32 PM
dieselJon's Avatar
Talking I did it! Now I can't get enough!
I turned up my smoke screw, turned the fuel pin and turn the AFC wheel 1/4 turn! Man, this truck has more low end power than I need! Now what should I do? I want to keep this a daily driver but also want to take this to the occasional pull. The full power screw is next, and then I was thinkin' maybe the 3200 rpm spring (Cant forget the boost gauge either!). The closet dealer is 45min-1 hour away for the spring. Would it be better to go there and get it or wait awhile an order it online? Your help is gladly accepted.
Also, when I turned the pin and smoke screw per instructions in sticky, my EGTs actually went down about 25*! But when I laid into it, it climbed more quickly then before. Did I do something wrong?? Yes I did make sure the pin was at its deepest point.
What y'all opinion? Money wise, I can buy all the goodies BUT I am a cheepskate. I dont spend it unless if I have to Help me in this arena guys. Thanks,
dieseljon
Old Mar 6, 2007 | 05:15 PM
Definitely do the 3200 RPM spring ASAP. You will wet your pants if just turning the AFC cone made you this happy.
Old Mar 6, 2007 | 06:31 PM
gman07's Avatar
Just wait until you get a few turns on the fuel screw
If you ever want to do some BOMBs or need help, let me know; I'm about 20 minutes west of Clinton. I also have a spare fuel pin we could grind and throw in your truck
Old Mar 6, 2007 | 07:05 PM
dieselJon's Avatar
It took me 1 1/2 hours this am to do the tuning. How long to do the full power screw? and the spring? With my paycheck this week a boost gauge is a cummins!
Old Mar 6, 2007 | 07:23 PM
gman07's Avatar
The full power screw shouldn't take more than 15 minutes, but the idle will need to be adjusted afterward, and that's a pain. The spring will be a little more complicated, but it's not too bad if everything goes smoothly.
Old Mar 6, 2007 | 08:38 PM
johnny5.9's Avatar
Buy a pyrometer before a boost guage. Your boost isn't that important at this stage but melting down your engine is.
Old Mar 6, 2007 | 08:59 PM
rlyons's Avatar
He must have a pyro already if his EGTs went down 25 degrees.
Old Mar 6, 2007 | 09:37 PM
MJDiesel's Avatar
I remember when I turned the full power screw the first time (all that power unleashed, and the cloud of black smoke following me)! Yeah, it was awesome!
Old Mar 6, 2007 | 09:41 PM
rlyons's Avatar
Once you cross over to the dark side you never return.
Old Mar 7, 2007 | 01:17 AM
1stGen545's Avatar
Thats how I started. Now I have a fuel pin lots of pump mods, POD's,HX35-14cm w/g, full 5" exhaust, and other goody's, Need 3.2K spring kit. My wife threatened to have me put in rehab for my addiction ( Diesel Power). Welcome to the Never Having Enough Club. Have fun.
Old Mar 7, 2007 | 11:12 AM
ryan10's Avatar
How do you guys get to the full power screw? i tried a regular socket, and it did not reach, then i went to a deep socket and it hit the fuel lines, and i can not get to it with a regular wrench? Thanks.
Old Mar 7, 2007 | 12:01 PM
janb's Avatar
Originally Posted by dieselJon
... BUT I am a cheepskate. I dont spend it unless if I have to ...dieseljon
a free 12cm housing from a bombed 2nd gen might be nice, look / ask around, you'll find one
Old Mar 7, 2007 | 02:04 PM
rlyons's Avatar
I use a ratchet boxed end wrench.
Old Mar 7, 2007 | 04:33 PM
I use a 13mm box wrench on the locknut and a 1/4" drive 6mm socket on the screw.
Old Mar 7, 2007 | 07:35 PM
ryan10's Avatar
ok, thanks.
Totallyrad
Jul 19, 2011 07:41 AM
jacobrw1983
Jan 17, 2011 12:11 PM
Boatnik
Aug 5, 2007 09:09 PM
