what does this do
what does this do
well i put my transfer case back on and i dropped it and i broke that sensor thats close to fuel tank what does it do is it important or can i live without it
there is a small gear in there the only thing thats broken is the tube itself no broken gears or bent little shafts
my speedometer doesnt work either.
Um, Oskifer? It done wont work. Didnt know I was doing 75 in a 55! Now can you foller an' done tell me when I hit 60 please.
A friend told me that part (the big black box) cost him around $60 and 15 minutes of time.
dieseljon
A friend told me that part (the big black box) cost him around $60 and 15 minutes of time.dieseljon
D92, the Variable Speed Sensor(VSS, the peice that screws onto the Speedo sender and that the electrical connector plugs to) can be got at NAPA for around $40. If your set up requires teh 90 degree gear reducer, that is a dealer only part that will run between $100 and $150 dependign on your application. If you broke the male threaded peice that is actually in the transfer case, that is the "pinion gear retainer" and I happen to have a spare one I'll send ya for nuttin if it will work for your app.
speedo
ok so its the speedo thats good to have
thanks chris ill check whats broke and get back to you guys
another question the semsor that is on the vibration damper is that for rpm what does that do for my truck i dont have a rpm guage
is that where i hook it up if i deside to put one in
thanks chris ill check whats broke and get back to you guys another question the semsor that is on the vibration damper is that for rpm what does that do for my truck i dont have a rpm guage
gap
i gapped it just did not try it yet havent finished putting it back together im a bit lazzy
but if it doesnt work what are the signs
no voltage on guage or something like that???
but if it doesnt work what are the signs no voltage on guage or something like that???
tex23455
Dec 12, 2007 10:31 PM
Common
May 7, 2007 01:58 PM
drewallen42
Apr 14, 2007 01:07 PM
VikingDiesel
17
Dec 30, 2006 09:19 AM
