Hybrid H1c
Old Oct 15, 2010 | 02:13 PM
chevelleriley's Avatar
Question Hybrid H1c
i am buildin a hybrid H1c, i am putting a 16cm exhaust housing with a 60mm compressor and a new 6blade wheel. what kind of boost do you think i will probably get out of this setup
Old Oct 15, 2010 | 02:20 PM
Onemoparnut's Avatar
That will depend a lot on your pump settings and what size injector you have in it.
Old Oct 15, 2010 | 02:34 PM
stock injectors and the pump will get turned up when i get this setup on here. Also where would i be abel to find a compressor upgrade for a resonable price?
Old Oct 15, 2010 | 04:32 PM
The 60mm is a compressor upgrade. I made 30 psi with a stock turbo and stock injectors. I would think you will make a little more.
Old Oct 15, 2010 | 05:59 PM
92betsy's Avatar
http://www.gillettdiesel.com/turboch...pgrades-2.aspx
It's $250 for the 60mm compressor here and $175 for the 16cm housing
Old Oct 15, 2010 | 06:11 PM
CaptainChrysler's Avatar
If you want the 6 blade wheel, you might have to call HTT. Last I knew GDS didn't mess with it. They just use the 8 blade.
Old Oct 15, 2010 | 06:21 PM
What is the difference between the 6 and 8 blade?
Old Oct 15, 2010 | 07:25 PM
The 6 blade flows a little more. It is a little louder too. It has a larger exducer, so you have to make a little room.
http://www.htturbo.com/cu.htm
The nice thing about the H1 series is that you can swap the backing plate for the compressor cover. The HX series wich would have to torn down and machined because the backing plate is part or the bearing housing. I also prefer the v-band holding the cover on as opposed the the giant snap ring.
Old Oct 15, 2010 | 09:12 PM
Is it worth the 425 plus a 50 dollar core over the 8 blade for 250 and no core?
Old Oct 16, 2010 | 08:24 AM
1993 250bluebal's Avatar
questioning the add site with the 6 blade wheel, says kit comes with a back plate. This add cost twice as the other upgrade with the cheaper one not haveing a backplate. Whats the purpous of the backplate?
Old Oct 16, 2010 | 11:23 AM
dieseldawg604's Avatar
it has a bigger back plate because the exducer is bigger and the stock back plate is to small to fit the bigger wheel!
in my opinion you would be better off finding a hx40 or he351 turbo
your probably gonna out grow that turbo pretty quick!!
Old Oct 16, 2010 | 03:44 PM
Probably not.
77machomopar
Nov 8, 2008 06:09 PM
RSWORDS
Jul 29, 2008 03:50 PM
CTDreul
Jun 11, 2008 05:24 PM
Rales
Aug 8, 2003 12:59 AM
Alec
Aug 5, 2003 02:43 PM
