hx40 specs
Old Sep 11, 2012 | 08:03 PM
Onemoparnut's Avatar
hx40 specs
I have a chance to get a hx40w for cheap how do I find out the specs from the numbers on the turbo?
Old Sep 12, 2012 | 12:29 AM
jimbo486's Avatar
It's gonna have a 60mm inducer, 6- or 8-blade compressor wheel, I can tell you that much. 16cm or 18cm turbine housing.
Old Sep 13, 2012 | 09:15 PM
Thqnks jimbo! Do you know if the exhaust housing off my h1c will go on the hx40?
Old Sep 13, 2012 | 09:22 PM
jimbo486's Avatar
Can't say for sure. I know the hx-40 compressor housings can be made to fit the hx-35. Don't know if it would work the other way around or even for the h1c. Did you find an hx-40 for cheap?
Old Sep 14, 2012 | 01:26 PM
Yea I can get one cheap just don't know if it is worth messing with or not
Old Sep 14, 2012 | 04:10 PM
Philip's Avatar
If its a 6 or 8 blade HX40. Pass on it. Those are not the best of the HX40 line up.
The 7 blade HX40 is the one to look for. Here is a link. On the right side of the page is a flow chart for the HX40 line up. The 6/8 blade fall into the standard class.
http://www.myholsetturbo.com/images/...mbers_2008.pdf
Those 6 blade HX40's can go down to a 56MM intake wheel also.
06RAMCTD
0
Dec 19, 2006 04:15 PM
Hawkeye
Sep 23, 2003 08:22 PM
21
Dec 3, 2002 10:10 AM
shaft01
Nov 22, 2002 08:46 PM
chevota01
Nov 12, 2002 05:10 PM
