hx35 turbo swap
Old Jan 4, 2011 | 03:22 PM
rockmike's Avatar
hx35 turbo swap
Hey guys im a newb still...
I have a 93 d350 5 speed,rock stock other than a rotated fuel pin and star wheel turned in a bit.
The truck will mostly be used for pulling about 12k goosneck.Ive got a new inj pump for it.Im planning on taking it down to Diesel Performance and have them work over the pump and install it.
I have a 4" Diamond eye system for the truck,that I will install.I was planning on buying the 60 mm stage 2 ? set up for the stock turbo.A buddy of mine has a 2000 cummins 5 speed and just upgraded his turbo and he said I could have his old turbo for free he said it was an hx35 do y all think this would be a better set up for me?
Discuss please.
Old Jan 4, 2011 | 03:29 PM
Well the HX35 is a good turbo, and for that price an excellent upgrade over your stock unit. The main difference in the two is the HX35 runs a smaller exhaust housing (12cm2) as opposed to the 18-21cm2? unit you probably have now.
If you don't want it I'll gladly drive down and pay you for it.
Old Jan 4, 2011 | 04:28 PM
rockmike's Avatar
I didnt get into the perticulars on it but doesnt the hx35 have a 4" exhaust outlet? so my D.P. its for the stock turbos 3" outlet.
If so I wonder if Diamond eye would swap me out for the 2nd gen D.P.
Old Jan 4, 2011 | 05:13 PM
JonathanFleguel's Avatar
hx-35 is 3 inch i have one and i like it
Old Jan 4, 2011 | 05:32 PM
Douglas2's Avatar
hey-Hey!!!,
I have one ov those turbo's on my 1990. I pulled the 12cm exhaust housing and put on a 16cm. Seems to build boost a bit faster than the H1C. It needed a new crossover pipe. I'd put up the pix but I have not gone to the trouble ov re-sizing them so that the forum can take them.
cheers,
Douglas
Old Jan 4, 2011 | 05:45 PM
92smokin blacky's Avatar
I say put the hx35 on, the 60mm upgrades are pretty expensive if you ask me. You should like it more anyway with a quicker spooling housing. And if its off a newer 24 valve, it should have the 58mm 8 blade compressor... am i right?
Old Jan 4, 2011 | 07:06 PM
Douglas2's Avatar
ummm...no, I don't think so... Gen 2 12V came with 8-blade, 56 x 83mm compressor with 52 lb./min flow. Gen 2 24V came with 7-blade 54 x 77mm compressors good to 60 lb./min. It suprised me that the smaller wheel flowed so much more than the bigger one; the 8-blade has a wider map at higher pressure ratios.
cheers,
Douglas
Canuckville
ABDTR #5
Oct 2, 2009 09:28 PM
Diesel_Storm
Aug 21, 2008 10:43 PM
BowtiedCTD
Sep 24, 2006 12:02 PM
signature600
Dec 14, 2004 06:05 PM
