HX35 60mm upgrade?
Old Feb 25, 2009 | 07:55 PM
sshort's Avatar
HX35 60mm upgrade?
I just installed the 60mm upgrade on a HX35 from GDS I have been tuning truck this afternoon & noticed the truck ran much better after turning full power screw back out so far backed out 3/4 of a turn still have heavy haze under power dose this sound right
Old Feb 25, 2009 | 08:06 PM
archer39's Avatar
how was it before the upgrade?? perhaps one of the intercooler boots are not hooked up right creating a boost leak.
Old Feb 25, 2009 | 08:36 PM
sshort's Avatar
idont think so ive got close to 40#s boost with a 18cm housing the truck runs better then it ever has but iam just thinking more air would need more fuel not less
Old Feb 25, 2009 | 11:32 PM
Alwaysworking's Avatar
alwaysonDTR
did you get the wheel tourqed right? seal on the compressor good and v-band tight?
over fueled at low boost causing the turbo to spool slow?
i have had my afc tuned loose as in not much afc spring tenstion and then raised the tenstion and if seemed better.
Old Feb 26, 2009 | 07:52 AM
sshort's Avatar
no v-band it is a HX35 18cm with snap ring I have no problem the way it runs I will go out this morning & due some more tuning. also boost is not low made 40# last time i ran it not even at full throttle. I had a 12 cmW on it & it made 45# boost but EGT was very warm very fast I switched to 18cm because i pull 15k with the truck
Old Feb 26, 2009 | 07:55 PM
93John's Avatar
Where is your aneroid and star wheel set at?
Old Feb 26, 2009 | 08:02 PM
sshort's Avatar
I adjusted star whl up to much fuel at low boost runs much better thanks aneroid? is there another word for this
Old Feb 26, 2009 | 08:25 PM
93John's Avatar
smoke screw. its on top of the pump.
Old Feb 26, 2009 | 10:32 PM
sshort's Avatar
it is almost flush with bottom of cover but has very good response just off idle
JHPC
Apr 15, 2011 06:50 PM
freight train
Jan 4, 2009 04:56 PM
'91 VE
Dec 12, 2008 12:17 AM
Free89W350
May 18, 2008 05:46 PM
cumminsdriver635
19
Dec 11, 2007 01:23 PM
