Htt Upgrades For The H1c
Old Jul 27, 2006 | 08:42 PM
90dodge's Avatar
Who Has Done A Htt Turbo Upgrade On There H1c's
Thanks,
Bob
Old Jul 27, 2006 | 11:58 PM
rebal's Avatar
me
get an hx35w and have more fun
Old Jul 28, 2006 | 12:06 AM
jrussell's Avatar
Why?
For the money I don't think you can beat the HTT Stage III.
Old Jul 28, 2006 | 08:20 AM
BIGTAN408's Avatar
I Run The Htt Stage Iii And I Am Really Pleased With It.
Old Jul 28, 2006 | 09:08 AM
JD730's Avatar
I have a HTT stage IV built and waiting to get swapped in. I cut the back plate myself and saved some money. Did a rebuild while I was in there too.
Old Jul 28, 2006 | 06:21 PM
rebal's Avatar
you can buy a good hx35w for less and im not really impressed with my htt stage 3 just my .02
Old Jul 29, 2006 | 05:59 PM
90dodge's Avatar
H1c Not A Hx35
Well I Am Interested In Upgrading The H1c. The Non I/c Turbos.
Can Anyone Give Me Some More Info, Be Sides That They Like It.
Thanks
Bob
Old Jul 29, 2006 | 06:08 PM
jrussell's Avatar
Have you ever tried an HX35 on your truck for comparison? I was under the impression an HTT Stage III H1C will flow quite a bit more air than a stock HX35, so not sure that HX35 is going to be any better or even as good as the hybrid.
Old Jul 29, 2006 | 07:59 PM
gman07's Avatar
I'm not sure what size compressor wheel the HX35 has, but I think it's 56mm. Upgrades from HTT are available in 56mm, 58mm, 60mm 8-blade, and 60mm 6-blade for the H1C. They all come with MWE slots too. Basically, if you put a 12cm housing and a stage I kit from HTT on an H1C, it will differ from the HX35 only in the way the housing is held to the CHRA.
Info on HTT upgrades: 4 stages available: Stage I, 56mm; Stage II, 58mm; Stage III, 60mm; Stage IV, 60mm, 6-blade design for a little more flow. They will all have MWE slots, which will make the turbo whistle a lot more, and they all cost $198 except the Stage IV at $285. As compressor size increases, so does lag (though I've heard it's a slight difference). The upgrades are generally used to cool high EGT's down by a few hundred degrees, though it will depend on mods done. If you need any more info, I'd give the people at HTT a call.
Last edited by gman07; Jul 29, 2006 at 10:48 PM. Reason: spelling and additional info
Old Jul 29, 2006 | 10:10 PM
dpuckett's Avatar
The nonIC turbo has a 50mm wheel, I believe. Later H1C have 54mm, and the rest has been listed. So, going to even a stock HX35 will be an improvement.
Daniel
Last edited by wannadiesel; Jul 29, 2006 at 11:35 PM. Reason: Please use the PM system instead of open forum.
Old Jul 29, 2006 | 11:36 PM
90dodge's Avatar
thanks
thanks gman07
bob
12V_shooter25
Dec 28, 2012 03:52 PM
O.T
16
Jan 14, 2008 02:47 PM
shawnboymoody
Apr 26, 2007 10:20 AM
Bobcat698
Nov 8, 2006 11:20 AM
acook
Apr 11, 2006 12:44 AM
