HTT IV? (long ?) sorry
Old May 2, 2008 | 10:07 PM
93flatbed's Avatar
I heard though the grape vine that the stage IV kit for the HC1 is no longer being produced? I tried calling HTT today and go put on hold for a long time, so I hung up. I was planing on doing this to my truck. So if this is true, and I assume it is, lots of guys are sayin it. What is my best option? HX35 or HX40? Also I'm goning to a PS intercooler with 3" pipes and a 24Valve intake. And I was planning on 370's but since I don't tow maybe bigger? I've got some money to play with so all suggestions are much appreciated. Oh yhea what clutch? That is really what I'm going to do first. I know lots say to get relined but here is my thing, I need the truck for work and I go 100+ miles a day. So sending it out isn't really an option for me.
So in sort I need advice on;
Clutch
Turbo (is the Hx35/40 a direct bolt on or do I need to modify downpipe, oil drian, and oil psi line)
Injectors
Anything else that I may need to know, still tryin to learn,
I'm sorry for my ignorance
Thanks in advance
Justin
Old May 2, 2008 | 10:35 PM
Alwaysworking's Avatar
alwaysonDTR
i think the gain with going stage IV over stage III is not worth the cost, the 60mm upgrade seams to be the best option for an h1c upgrade and with a 5speed i read that a 12cm wg housing works real well if you mod it.
try http://www.gdsdieselparts.com/new_page_2.htm
i got the CH-o5 which is the 60mm for $197 something
p.s there are cheaper than htt
Old May 2, 2008 | 10:37 PM
MikeThomas's Avatar
Check out my sig, I have the mods you are questioning. Im running an HX35/12 at the moment b/c the Stage IV/14 is being used in a mock up. I think its a good combination, but the stock hx35 runs about 150 degrees hotter than the stage IV.
Old May 2, 2008 | 11:03 PM
93flatbed's Avatar
That is good news. Mike when you switched to the 35 did it bolt up or were there some mods? Also I'll go a modded 35 do you think I can go bigger than 370's? I was planning on a valet switch also. I can wire it into my pyro, it has a grounded wire when it hits a preset EGT level, I can make it defuel when the EGT's get too hi.
thanks Justin
Old May 3, 2008 | 09:59 AM
MikeThomas's Avatar
Bolts up like it was born there!
Old May 3, 2008 | 11:07 AM
93flatbed's Avatar
good deal, I'm looking around for one. I went out for a little drive today and I saw a 92 in the back of a guys house. He wants to sell it, he said he would think about it for a little while and call me. I got the impession he dosen't think it's worth much. I may have a builder on my hands. Well I hope I will.
Old May 3, 2008 | 07:55 PM
PToombs's Avatar
The GDS Stage IV kit is the same as HTT's, but you have to machine your backing plate. HTT sends you one.
Plus, GDS is about $100 cheaper.
Old May 3, 2008 | 07:56 PM
JQmile's Avatar
They're still being made, although I think they are having trouble finding good cores.
Old May 3, 2008 | 08:24 PM
mhuppertz's Avatar
I can't say enough about how awesome the HTT stage IV is! Turned my truck into a snarling beast (along with the POD's, pump mods, and 3,200 spring).
O.T
16
Jan 14, 2008 02:47 PM
Totallyrad
Jan 7, 2008 05:31 PM
Bobcat698
Nov 8, 2006 11:20 AM
ekim440
Jun 10, 2006 05:53 AM
Got Smoke?
Feb 8, 2006 11:36 AM
