How much weight will the bed handle?
Old Feb 12, 2013 | 11:44 AM
ouchman's Avatar
I have a D250 and I am expecting a delivery of palleted goods that weigh around 1600lbs. The only way I can accept delivery is to have the driver drop it on the street where I will have to break down and carry each item individually, OR I can have them roll the pallet directly into the bed of the truck.
I will not be driving anywhere with the load, just about 75 feet where it will stay parked until I am able to unload it.
Is 1600lb pushing the limit too far?
Thanks
Old Feb 12, 2013 | 12:47 PM
jstone44720's Avatar
1600 lbs is not a problem.
Old Feb 12, 2013 | 12:49 PM
crazzywolfie's Avatar
i don't think 1600 would be too much for a d250. i could legally hall that in the bed of my 81 d150.
Old Feb 12, 2013 | 12:57 PM
Rick 12v CTD's Avatar
assuming the rear suspension is the same as my old 91.5 w250 with the 7 leaf pack, ive literally put 3 times that amount of weight in the bed. you should be fine
Old Feb 12, 2013 | 01:36 PM
j_martin's Avatar
That's just about the weight of a concrete bed liner.
Old Feb 12, 2013 | 02:11 PM
1STGENFARMBOY's Avatar
I haul over 5k on a regular basis.
Old Feb 12, 2013 | 02:45 PM
ouchman's Avatar
Thanks guys - been a while since I dumped that much weight on Ol' Grumpy. Just making sure.
(Plus I am lazy as hell and do not want to hand-haul that load!)
Old Feb 12, 2013 | 06:30 PM
j_martin's Avatar
You might be confusing wisdom with laziness.
Old Feb 12, 2013 | 07:04 PM
NE frmhnd's Avatar
I usually get a ton on when I haul scrap. Not sure it won't bow under the wheels of a hand truck, but it will hold the pallet just fine.
Old Feb 12, 2013 | 07:29 PM
gyman98's Avatar
3 strips of 3/4" plywood fix that problem. Not sure 1600lbs would be enough to dent the bed ribs in though
Old Feb 12, 2013 | 07:37 PM
james1's Avatar
Smile
I recently loaded two tons of topsoil in my truck and my son then drove it 120 miles at freeway speeds. I put 85psi in the rear tires and enough air in the rear Keldermans to make it look legal; no problem whatsoever. I do have good plastic bed liner.
Old Feb 12, 2013 | 08:49 PM
John93CTD's Avatar
Well I had the local Sutherland load a full unopened Pallet of quickcrete on the bed of my w250 an it squatted the Edit out of it. I thought it was going break my springs, now it doesn't help that they are the factory springs and the overloads were gone. Gonna replace all of them soon.
Bad Ramer Jamer
Jun 14, 2008 10:16 PM
Bounty Hunter
Mar 5, 2007 09:14 PM
tenmile
Jul 20, 2006 07:07 PM
Dodgezilla
Apr 11, 2004 10:48 PM
