How much weight?
How much weight?
Just curious... how much weight do you guys put in the bed of your truck when the roads get slick?
I carry 400 lbs of bagged rock salt in mine, plus about another 150lbs of cord wood or what ever is laying around....but I always wonder if its enough....
what do you guys use and how much????
naw, the duallys are the worst on a slick road.. they float so easily, and with such a small contact patch, ya got no traction at all untill ya drop some wieght on 'em...
I currently have 850 lbs in the back of mine. Still doesn't want to get traction from a dead stop, but it sure rides a lot better.
Wife's truck = put a pallet in the bed, against the tail-gate. Stack several 100-pound sacks of horse-feed on the pallet. Leave it in there, until the slickness is gone, then feed it to the horses. It don't get wet; she has a topper.
My truck hits the scales at 9800-pound; I usually don't add anything to it.
If not hauling anything, drop the air to around 30-PSI to make a longer track.
I was thinkin about adding some. The 92 w/ 5 spd gets awfully squirelly in the snow. I guess its the combo of torque, heavier front end and l/s rear. I've had alot of Dodges and some Ctds and this one is a little scary. Then again, I never commuted to work until recently. I give the 2wd dually guys A LOT of credit makin' it around in those rigs!
My flatbed was the weight (added 1200lbs) til October when I swapped beds. WIth the flatbed, two flats on the rear, and wet slick snow on the ground, I backed up the hill of the street we lived on at the time. Now it wont hardly go on slick grass.
We dont get enough snow/ ice around here for it to be an issue. 93beater- in ElPaso, I wouldnt think you'd have much problem in inclement weather, either.
DP
DP
I had half a ton of cinderblocks back there and still couldn't get it to start on a hill. Even empty it is fine once you are moving - it's getting moving on a hill that is the problem. Massive torque at idle and a grabby clutch = instant wheelspin.
Now I don't bother, I just drive something else if it looks like snow.
Well, my 400 lbs of salt wasnt enough to get me started on about a half inch of ice on my gravel driveway this evening when I got called into work early.
Got an old 55 gallon drum, layed it on its side and filled it with water..about 480 lbs more, so now i have about 1050lbs back there, and i was able toget rolling...
this is my first 2wd, and my first auto, and i want my 4w 5 speed back!!!!!!
