How much lift to fit 20x12.5 33”s with no rubbing
Old May 5, 2020 | 10:22 AM
Coalrolling59's Avatar
How much lift do I need to fit 20x12.5x33” wheels and tires? I do not want to trim the mint body at all so it has to clear all the way I also want to keep it as low as I can. Any ideas? I really would like some stance. Thanks
91 dodge w250 5.9l diesel
Old May 5, 2020 | 10:29 AM
You posted this same questions a month or two ago.........I remember because I took the time to answer your question then.
I can fit 33X12.5 rims on a stock Cummins truck with NO LIFT on STOCK rims.
So the wheels you are using will make all the difference. If you get wide, offset rims you will need to lift it. The wider and more offset they are the more lift you will need.
So without knowing the rims you are going to use, I don't know what height lift you will need.
Old May 5, 2020 | 11:39 AM
DevynBurk's Avatar
custom offsets gallery is a great tool.
I run 20x10 -24 off set wheels 33x12.50R20's no lift and dont have any rubbing issue
Old May 6, 2020 | 08:36 PM
I would be putting on 20x12.5x33” tires on 20x12x33” wheels with -44 offsets
Old May 7, 2020 | 05:24 AM
DevynBurk's Avatar
Stock height your gonna rub, I rubbed with my old setup 20x12 -44 305/50R20 (32x12x20). Id say look for at least a 2" lift. if you go 4" i would try 35's i think 33's look small on a 4".
Hoss
Nov 5, 2012 10:19 PM
initiald843
27
Feb 13, 2008 12:05 AM
squirrel
Off Road / 4x4
Feb 4, 2008 01:48 PM
Its All Good
May 21, 2005 11:36 PM
jtbear
Aug 1, 2004 08:10 PM
