How to keep around injectors dry
Old Feb 7, 2011 | 07:04 AM
ClassA4x4's Avatar
I've replaced the return line washers and the small banjo bolts on the injectors are as clean and tight as they can be. There's still seepage around at least 3 of the injectors. The high-pressure lines/nuts are dry.
What could be wrong?
Old Feb 7, 2011 | 07:31 AM
Subliminal's Avatar
When I had that issue, it was the big hold down nuts weren't tight enough...and it was coming out of the bores. I think...lol.
Also, possible valve cover gasket issue?
Old Feb 7, 2011 | 05:25 PM
Richie O's Avatar
366 Spring Chicken
I have had issues before. What I did was get them tight, then lightly tap on the banjo and retorque. Just be careful, they are pretty weak. I was afraid also of stripping the threads.
Old Feb 8, 2011 | 12:51 AM
GLHS's Avatar
Have you changed the injectors lately?
If yes, did you reuse the old copper washers or install new washers?
I sometimes reuse the washers.
I sometimes have leaks.
Old Feb 8, 2011 | 11:54 AM
big_red's Avatar
just torque down the hold down nut to 44 ft lbs. it should stop the leaky injector
Dave88LX
Sep 2, 2025 10:30 PM
SOhappy
Sep 15, 2009 08:34 AM
Big C
25
Nov 3, 2008 12:40 PM
dodgeboy59td
Feb 20, 2007 08:25 AM
Diesel-Dan
13
Aug 24, 2005 09:50 PM
