hotest coolant spots, need answers quick
Old Mar 24, 2006 | 10:27 AM
tyssniffen's Avatar
Folks,
I'm converting to veggie oil (I'll be posting results soon) and I need to run hot coolant through various things to heat the oil up before it hits the injectors.
Where's the best place for me to T off the coolant? here's a picture with some numbers on it.
Thanks as always,
Tys
Old Mar 24, 2006 | 10:46 AM
JD730's Avatar
Coolant will be hottest at points 1 and 3. Return though 2 or 4. It probably will affect your cab heat if you tap there in the winter. You may need to do some valving to get both circuits for flow right.
Good luck with it.
Old Mar 24, 2006 | 11:13 AM
mhuppertz's Avatar
Use a ball valve from Home Depot to modulate the flow between cab heater and heat exchanger for the bio.
Old Mar 24, 2006 | 11:37 AM
tyssniffen's Avatar
thanks,
hey, there's a laptop at the shop! so I can check this all day. anyone else have input?
I'm not too worried about the heat; I'm in the Santa Cruz, CA area, and my wife can just suffer through the occassional cold.
Old Mar 24, 2006 | 01:54 PM
flashgordon's Avatar
I realy don't know much about byo fuel but what i was told was that it worked fine down to about 40*before you had to heat it but i'm not positive tho???????
Old Mar 24, 2006 | 02:15 PM
bgilbert's Avatar
#3 or the 1/2" pipe plug to the left of it if you don't want to mess with that coolant elbow and or want to run a nipple out of the unused 1/2" tapped port.
Machinos
Jun 15, 2010 09:06 PM
Cummins Freak
Mar 2, 2010 06:06 PM
CTDinMT
Dec 30, 2006 10:28 PM
troutdog
Sep 1, 2003 11:39 AM
ROCKNRAM
Oct 31, 2002 10:46 PM
