Holy boost!!!
Old Oct 18, 2008 | 07:39 PM
feveree40's Avatar
Holy boost!!!
Just finished up my turbo upgrades this evening and took her for a test drive. What a test drive it was! First time i spooled it up good the gauge shot straight to 45 psi. I didnt keep in it long enough to get a real good egt ready, but it started to level out at 1100* at WOT. I expected the drop in egt's with the 60mm compressor, but i also expected a little less boost. That 12cm housing sure spools quick. Am i going to blow apart this H1C based turbo running 45+ psi? 45 psi was after a only 2-3 seconds of WOT on a flat road, i am scared to really get this thing under load and see what the boost tops out at.
Old Oct 18, 2008 | 07:42 PM
I don't like to spin 'em much past 40 psi, it's rough on the turbo and on the head gasket.
Is that a wastegated housing? Just hook up the wastegate to a manual boost controller set for 40 psi and have at it.
Old Oct 18, 2008 | 07:57 PM
feveree40's Avatar
its non-wastegated, so... ? Is there any way to set up a "pressure relief" in a boost tube? I guess thats what they make wastegates for
Old Oct 18, 2008 | 08:00 PM
Nope, if you've still got the 18.5 laying around put it on, that should get you back below 40 psi.
Old Oct 18, 2008 | 08:03 PM
feveree40's Avatar
dang it, that 12 is so much fun. I still have the 18.5, will it lag much more that stock with the 60mm wheel?
Old Oct 18, 2008 | 08:06 PM
Nope, it'll run about the same. If you've tweaked on the fuel screw since you took it off, you'll be surprised at how well the 18.5 spools with enough fuel.
Old Oct 18, 2008 | 08:14 PM
feveree40's Avatar
I havent touched the fuel since i put the turbo back on. I was putting out black up through 2500 rpm, isnt that enough to spool it?
Old Oct 18, 2008 | 09:21 PM
SuperiorRam's Avatar
mine has benn spoolin 45 for 2 years now HTT stage 3 and 12 cm2
Old Oct 18, 2008 | 09:32 PM
feveree40's Avatar
So you have your boost controler set at 45psi? How much pressure will it make with the wastegate pinched off?
Old Oct 18, 2008 | 10:01 PM
Free89W350's Avatar
My truck is a auto and after I put the HX w/ the 60mm wheel and the stock 89 18.5cm housing I would hit 45lbs easy and it spooled up pretty quick. Since I put the Powerstroke innercooler in it it seems to max out at about 42lbs and the pyro gets around 1300* and seems to stay there.
Old Oct 19, 2008 | 05:07 AM
jogl's Avatar
Feveree40, what was your boost maxing at before the upgrades?
Thanks,
JP.
Old Oct 19, 2008 | 10:52 AM
feveree40's Avatar
with the stock turbo i was maxing at right around 40psi, but it was real jumpy from 38-40.
Old Oct 19, 2008 | 12:15 PM
W150CTDproject's Avatar
1st of all, Feveree40 ur truck on youtube inspired me to buy my own CTD lol. but anyways i think if you get an intercooler and/ or put on the stock housing you'll be safe in boost range, or it may max out at 40-45 depending on fueling. But thats my guess.
Old Oct 19, 2008 | 02:08 PM
pwrtripls1's Avatar
You gotta be careful about that drop you see in boost with adding an intercooler. The turbo may still be pumping out 45 psi at the compressor but after the IC drop you may show several lbs. less and think your safe when your not. Boost drop can be bad the smaller the IC is.
Old Oct 20, 2008 | 10:34 AM
feveree40's Avatar
So i've been thinking... what if i plumb a pressure relief valve from a water heater (30 psi) into my boost tube? like this one http://cgi.ebay.com/NEW-3-4-X-3-4-SA...d=p3286.c0.m14
