Holy boost!!!
Old Oct 20, 2008 | 10:39 AM
feveree40's Avatar
or more like this!
http://cgi.ebay.com/AIR-COMPRESSOR-A...d=p3286.c0.m14
Old Oct 20, 2008 | 10:46 AM
BigErksG2's Avatar
I think you would need a handful of them to keep the boost down. For about 50bucks you can get one intended to be used on our trucks.
Old Oct 20, 2008 | 10:53 AM
feveree40's Avatar
really, where might i get such a relief valve? those air compressor relief valves are only rated for 80 cfm, so you are right about needing more than one.
Old Oct 20, 2008 | 01:35 PM
big stinky's Avatar
If your running a wastegate you can run a manual boost controller. If not, you can get an external wastegate.
Old Oct 27, 2008 | 12:12 AM
tcs 91's Avatar
i ran 50-55 #s max on orig hd bolts for a long time. i don't drive it hard except when it matters but it never failed. max hp was 425-550 range. [that looks like a pretty big range, huh?] it just kept growing. timing probably the most important. mine wasn't too high most of the time.
Old Jan 13, 2009 | 06:55 PM
feveree40's Avatar
Name:  dtr turbo2.jpg
So this was my attempt at a "boost relief valve" It failed. Even with the valves back all the way out it didnt make a difference.
So I got a wastegated housing. Works good, but i need to do some fine tuning with a manual boost controller.
dealseeker
Feb 7, 2003 10:57 PM
Stevie G
Nov 21, 2002 10:42 PM
Dieseldude4x4
53
Nov 12, 2002 07:00 PM
Rammin On
Oct 7, 2002 02:31 PM
