history lesson on the truck tonight
I have timed many of these trucks, and have always had lots of room to advance it more than necessary without problem. I wonder if someone may have put the inj. pump gear in one tooth out of mesh. That would be a way to correct the problem, remove the gear cover, remove the gear and replace it one tooth away. It would be a good idea to actually check the timing to see where it really is first. It shouldn't be required unless someone has screwed with it before.
Brian
It's definitely a possibility that the gear is a tooth off, but I don't think the timing cover would have to come off for that head gasket job
Still, when I had my pump off, I could feel that the gear was just kinda hanging out in there...don't know if there was enough room to jump a gear w/out taking the cover off, but it was close. Maybe somebody did the kdp and had the pump off at the same time---then the gear would probably just fall out when the cover came off
g
g
Re: Wearz da pikturezz???
Originally posted by SSV1761982
Howdee, Did you get anywhere with the timing yet?
