Help!!!! Truck Falling Apart
Old May 13, 2011 | 12:43 AM
  #31
DJ Turbo.'s Avatar
Well it sounds as if it may just be the fact that it hasn't had a really good run in about 7 8 months
Old May 13, 2011 | 10:44 AM
  #32
pwrtripls1's Avatar
Originally Posted by dieselJon
My 2 cent worth.
Both of my 1st Gen Cummins trucks NEVER warmed up while idling. Even the defroster didn't work. There was no warm coolant.
Now the DMax thing is YEARS ahead. They have programmed a high idle into them to heat them up.
My brother had a 01 Powerstroke. Once started, after about 30 seconds, the flapper about 6" behind the turbo in the exhaust piping closed. This added back pressure and raised cylinder temps, to warm the truck up. Yes, the idle also increased.
I can see low combustion temps being a particular hazard. When a competition diesel starts up and idles, there is a lot of white smoke. Consistent with low combustion temps, there is a certain amount of fuel escaping. So, if idling for a long time below 1000 rpms (the very least), a cylinder wash down can happen.
I have let my trucks idle while I ran into the store to get a few items. 30 mins later, there was not a lot of heat in the coolant left. Both of these trucks had optimal working cooling systems.
Now adding a brick to the pedal and raising the RPMs did the trick in sub-zero weather. 5 mins of idling and a heavily frosted windshield wasn't heavily frosted anymore.
Just my $.02 worth.
True, when my Dmax IAT or coolant temp are below 45*F the turbo chokes down and idle increases to 1,100rpm. It keeps it like this till the coolant temp reaches 140*F. With 5" turbo back straight pipe it gets really loud and the turbo screams! It averages 4psi boost and around 450*EGT on elevated cold idle. But normal idle in the summer is only around 250-275*. Very cool running engine.
The old dodge though has electric fans which greatly aid in warm up. They kick on at 185*. Takes about 20-30 minutes idling before they come on in the winter. (houston "winter" that is) Every since putting the 4 hole DDP4's in I get a slight white haze at idle, till it warms up. Then its clean.
Like most heavy equipment, when it sits for too long it runs dirty till you work it and put a load on it. Then it runs like a champ! The 4bt in our loader was bad about white smoke when its sat even a few days. But once its run awhile, or run every day, its clean.
cazman
19
May 26, 2009 09:40 AM
ted_pulliam
Jul 22, 2008 09:30 AM
mhuppertz
Apr 30, 2007 02:02 PM
apache
Dec 12, 2004 10:30 PM
PADZZ
13
Apr 13, 2004 08:36 PM
