Help with performing a test on my brakes please:
Old Feb 21, 2020 | 08:36 PM
highwayrepair's Avatar
I'm trying to perform the following test:
"The rwal valve is pretty easy to test for internal leakage. There is a rubber plug in the end of the accumulator. Remove it and stick a straightened out paper clip in the hole until it bottoms against the back of the
accumulator piston. Have a friend step on the brake pedal. If the paper clip moves the dump valve in the Rwal valve is leaking."
I was under the impression that the RWAL valve was located on the driver side frame rail above the rear axle. When looking at this unit on my truck I do not see a rubber plug anywhere to remove to perform this test. Am I looking in the wrong spot, or just not looking hard enough? Any help would be greatly appreciated.
Old Feb 22, 2020 | 05:06 AM
KRB's Avatar
KRB
Your "car" meaning your Mercedes? Or your truck?
Old Feb 22, 2020 | 09:40 AM
On my truck, sorry.
Old Feb 23, 2020 | 04:25 AM
KRB's Avatar
KRB
Ha ha, makes a difference.
If I recall correctly, it looks kinda like a brake bleeder on a little valve thing. But I've never messed with it and not even looked at it for a long time so hopefully someone that has will chime in.
Old Mar 2, 2020 | 04:58 PM
I saw what looks "exactly" like a brake bleeder port on this rear abs module (on frame above rear axle), but I just assumed that it was in fact a bleeder port. Can anyone chime in if this is in fact the thing I'm supposed to be testing, and not an actual bleeder port?
stock12valve
Mar 30, 2018 12:40 AM
td3620
Mar 29, 2015 05:57 PM
Subliminal
Feb 3, 2011 07:56 PM
rebal
Sep 14, 2009 11:02 AM
MikeThomas
Jan 29, 2007 08:50 PM
