help my engine blew up
Old Aug 20, 2006 | 11:16 PM
65fury's Avatar
Exclamation help my engine blew up
hey guys big problem my engine overheated and then a big boom sound and the radiator fluid spewed from uder the hood. so i pulled off the side of the road and checked out he enginr, all i could see is that the radiator was boiling, no leaks or holes from anywhere, but before the big sound and spewing coolant the engine seemed to have lost compressin as i was cresting over the hill and then the boom and fluid, but before i had pulled off the side of the road the engine had already stopped running, there werent any rattling or bad sounds, it just stopped running. so i let it cool down checked all fluids and they were all fine, then i went to start it and it sound like the rods and every thing was just flopping around, so i go to crank it a second time and nothing, the engine just siezed up so im really confused a t what happened, if anyone hasx had this happen or has any idea what happened i would really apprecicate it, also how much would it be to puta 1994-1998 12valve into one of our trucks??? thanks for any help
Old Aug 20, 2006 | 11:23 PM
greasemonki's Avatar
my guess: head gasket blew, and you probably ended up melting a piston or two. Not to mention bearings are probably toast. I believe there is a 12v posted in the classifieds (or at least parts).
Old Aug 20, 2006 | 11:26 PM
mopar2ya's Avatar
I had a guy driving for me with a 1990 non I/c truck and he did very much what you described. What was amazing is it knocked like no other and puked massive oil out the dipstick tube. He was on I-80 in Nevada pulling a load of trailers when it happened, he drove to Oregon then to Idaho where he picked up another load and drove to Texas and then pulled the head. !/2 a piston was welded to the cylinder head.
In your case something is jammed in the engine, could be a rod, Id try to turn the motor backwards with a wrench, but it pretty much sounds dead.
Old Aug 20, 2006 | 11:32 PM
Platinum_Racing's Avatar
If you overheated the motor to the point where the block cracked the cylinder could've filled with anti freeze. After that happened the piston may have tried to come up on the fluid and snapped a wrist pin. Fluid is only compressible by a VERY small amount, so if the engine hydrolocked it would've caused damage. After the wrist pin broke, the conrod may have come around and cracked against the block, sending a mix of engine oil and anti freeze all over the place..... We did something similar in a 468 cubic inch Chevy big block SuperModified Race car..... 835HP and we wound up putting a conrod through the oil pan, but not before it came around and cracked a hole in the block, spilling that oily goo all over the racetrack.... That was a mess and a half.
Old Aug 21, 2006 | 12:18 AM
65fury's Avatar
hey thanks alot, i had a feeling something was toasted, but there aren't any holes or dents in the oil pan or block, but in a day or so im going to pull the head a see what my pistons look like, so does any one know how hard it would be to put a newer 12v into my truck, i have access to one for like 2 or 3 thousand dollars, or should i try to salvage my engine and rebuild it???
Old Aug 21, 2006 | 12:40 AM
Ilikebikes's Avatar
Wow, you don't hear that happening to cummins too often!
Old Aug 21, 2006 | 12:50 AM
PapeCAT's Avatar
pull the head first and let us know what you find
Old Aug 21, 2006 | 03:40 PM
Rebuilding these things is very expensive. If it's worse than a head gasket (and it sure sounds like it) a used motor will be cheaper. If you have access to one for under $3k you will be way ahead to swap it in. A later 12 valve will drop in like it grew there. You'll have some minor issues with the intercooler pipe, and the wiring for the shutown solenoid, but nothing too difficult.
Old Aug 21, 2006 | 05:17 PM
59FORD's Avatar
I say you burned a piston or two. Don't keep starting it
you will only risk cracking a cyclinder and have to have it bored
and sleeved, I know I been there, done that and it ain't cheap.
59
.............who has a spare block!
Old Aug 21, 2006 | 07:43 PM
Bill Tomlinson's Avatar
Sorry about your problems.
What did your pyro say when it happened?
Old Aug 21, 2006 | 08:25 PM
65fury's Avatar
hey thanks wanna, i was hoping some one would now about a newer 12v install, i thought i found one but went back t othe pick and pull and noticed it was a 24v, and they want too much for it, but there is some one on this site selling a 24v with a complete wiring harness and ecu with less than 67000 miles on it for 4500 obo, but i have a feeling that a 24v doesn't just bolt right in!!?? so i any one knows id be glad to know how easily it is and expensive, also will my tranny (727) bolt on to it?thanks
Old Aug 21, 2006 | 09:25 PM
mhuppertz's Avatar
Sorry man!
I'd say either a piston skirt broke off and wedged between a crank counter weight and the block, or you list a rod cap and the rod is wedged between the rod journal and the block. Either way, it ain't good.
Hope I'm wrong.... keep us posted.
Old Aug 22, 2006 | 12:09 AM
Originally Posted by mhuppertz
Sorry man!
But if it was that you'd think that the rotating mass of the engine would send it in pieces or through whatever it was wedged between.... That's the case with our SuperModified motor we blew...
Either way, it's not good and should be investigated.
Old Aug 22, 2006 | 07:58 AM
mhuppertz's Avatar
Remember, it locked while cranking, not while it was running. Otherwise I would agree totally.
Old Aug 22, 2006 | 03:32 PM
There's gonna be a LOT of wiring, but it will bolt up to everything.
