HELP! im half way there
Started putting my 3200 spring in and began taking the pump apart. i have all of the fuel lines and throttle linkage disconnected. the 4 allen bolta are out and i can seem to find anything else to take off. could it just be that i need to tap it with a hammer or jiggle it more? i have a little bit of fuel running out the back of the pump. am i there or have i forgotten something?
Mine had one little bolt and nut on it too if i remember right. It was goin through a hole on the drivers side of the pump, I just took it out and left it out. If it's leakin fuel though, then that means it should be about to come off, You may have to kinda twist it a little and it should pop off. The fuel screw pushes hard against the lever inside there. And it won't just come off, you'll have to pull it up a bit, then disconnect the spring from the tophat then it will come off all the way. Just keep a finger behind the tophat part when you disconnect the spring so it doesn't spring out and lose the tophat pieces, I did that and had to wait a month to get the tophat part cuz i couldn't find it.
tap on it lightly, it should pop off. AFC line and Fuel return, and the 4 allen bolts. The rear bolt closest to the head has a small sleeve that the top cover fits onto, so it has to come off that too.
I second taking the fuel screw out first if you can.
I followed this (http://dens-site.net/Dodge_CTD/Gover...ing/index.html) when I did mine and everything went without a hitch. Well, except that I forgot to write down the index marks for the throttle shaft so the truck would only start if I had the pedal half way to the floor. DOH!
It was an easy fix. Index it right.
ok. getting pretty frustrated by this point. after i pulled the full fuel screw out i went to town and left my buddy at my shop. he then called me and said it was off. foolishly believing him i wrote on here what he had told me. turns out he had simply removed the afc cover i had sitting on top with the four screws half way in so i didnt lose anything. so i am still unable to pull the top of the pump off. i have tried gently tapping it with a hammer and wiggleing it but it isnt even loose enough to wiggle. please help before i lose it and put it back together without the spring and take it to a shop and fork over 2-300$
does anyone have a diagram of a ve pump that has all of the washers and gaskets and everything so i could see if there was something i was missing and it would help in the reassembly. this is more work than i thought it would be...
