Help! Fuel Leak
Help! Fuel Leak
I need help fixing a fuel leak I discovered. There is fuel seeping about 1/4 inch above the fuel filter on my 93 W350. I thought it might be the fuel line from the lift pump but it isn't. I can dry the area and watch the leak begin once I start the engine. It is leaking directly above the sensor below the fuel line.
remove the fuel filter and inspect the fuel heater it is attatched to. there is an o-ring seal between this and the head. look here for more info https://www.dieseltruckresource.com/...r-t258221.html
The o-ring that the heater attaches to the head sounds like its the one you want. I ordered mine from Cummins Rocky Mountain, the p/n is 3913695 (my truck is an '89) the part was $2, I ordered a spare.
What you describe is EXACTLY what my truck did. I replaced the o-ring and the leak stopped.
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
