Help with E-brake and Anti-lock Lights on Dash
Old Aug 19, 2010 | 11:28 AM
DHT's Avatar
DHT
Mine just came on last night and won't seem to go off bythemselves! Is there a correct way to fix them without diconnecting wires! Before I replaced the mastercylinder and booster about a month ago they would come randomly and I could pump the pedal and they would always go off! Since replacing them they have not come back on until now! Any advise would be greatly appreciated! thanks! Dan
Old Aug 19, 2010 | 09:14 PM
Have you checked for ABS codes? Info is in the sticky.
Old Aug 20, 2010 | 10:00 AM
DHT's Avatar
DHT
Thanks soo much for the help!
Old Aug 20, 2010 | 10:13 AM
Onemoparnut's Avatar
Well what was wrong with it?
Old Aug 20, 2010 | 05:28 PM
Hector-BD's Avatar
Vendor - Former Vendor
if this is in the 92 truck and you have an exhaust brake Check your exhaust brake for vacuum leaks in any of the hoses.
Old Aug 24, 2010 | 11:51 PM
kbhblazer's Avatar
There is a vacuum looking canister mounted on the drivers side fender, there is a vacuum line going to it from the vacuum booster. If there is a vacuum leak in the line( the thing sends a low vacuum signal to set of the brake light if it fall to 8.5 hg) if you have a vacuum leak, bad hose ect. it will make the brake light come on. That is probably the problem.
Old Aug 25, 2010 | 10:29 AM
DHT's Avatar
DHT
Unplugged the connector behind the glove box and waited for it to reset and everything is back lovely with No lights on! Thanks for the help guys!
Old Aug 25, 2010 | 06:29 PM
whosdunit's Avatar
what connecter? maybe it will fix mine!!! But then it'll be totaly dark !!!!!!yepps!!!
dzl_damon
Oct 26, 2009 11:00 PM
polaris800sp
Nov 13, 2008 05:35 PM
ro9beam2002
Mar 15, 2008 09:54 PM
DODGEZILLAW350
May 20, 2007 06:00 PM
CHarlan
Aug 6, 2003 08:40 PM
