Help......
Old Nov 6, 2016 | 02:02 AM
Brian.B's Avatar
Help......
Hey guys.....my truck has been chugging bad.....it's worse in the morning at idle but then it kinda clears up but from off idle to around 1500 she sputters pretty bad and you can feel the loss of power but once it gets over 1500 or so it runs like a beast......I've put 2 different filters on it....but no change....any ideas
Old Nov 6, 2016 | 05:53 AM
sooty's Avatar
im sure you checked fuel flow volume, crack each injector while running to see if its staggering on one cylinder or more.
Old Nov 6, 2016 | 06:02 AM
Brian.B's Avatar
I did that and when I cracked them each one made a difference........
Old Nov 6, 2016 | 06:17 AM
deere country's Avatar
Sounds like you need to pull your injection nozzles out and have them checked as long as you confirmed your fuel supply to the injection pump.
Old Nov 7, 2016 | 10:15 AM
Brian.B's Avatar
How much pressure should the lift pump be putting out and can I tee in a vacuum and fuel pressure guage to check it.......usually when my lift pump goes out it will die at idle or when stopping fast......it idles fine......but thos thing does have over 600,000
Old Nov 14, 2016 | 09:54 AM
Brian.B's Avatar
It's getting worse now it's doing it through the whole rpm range
Old Nov 14, 2016 | 01:00 PM
JPrewitt's Avatar
Brian check your KSB solenoid connection on the IP.
Old Nov 14, 2016 | 01:52 PM
Try disconnecting the KSB. I can not run mine with the M/H timing spacer....tosses way too much timing in while the KSB is running, and I have all kinds of issues.
I also had the air temp sensor start to go out on me and would cause the KSB to stay on at random times, and eventually all the time, and with the M/H spacer I had lots of random issues.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
