Help!!!
Old Feb 21, 2009 | 12:27 PM
XCLR8N's Avatar
Help!!!
I had an orginal thread about bleeding the brakes here:
https://www.dieseltruckresource.com/...d.php?t=233768
I decided to try and bleed the brakes before going through with the RWAl bypass just to see. Sure enough the lines was riddled with tons of air. I am assuming that was due to no fluid in the reservoir.
Now on to the biggie.
I was done bleeding and got in the truck and started it up still on the stands.
I was checking the feel of the brakes and noticed a slight pulse int he brakes while applying them. I looked back and I saw that the rear wheels were rotating forward. I looked back down because I knew I was in NEUTRAL. sure enough I was and then I cycled through the gears and the tires were moving in NEUTRAL.
Is this normal?
Old Feb 21, 2009 | 12:30 PM
mishkaya's Avatar
I think it's normal as there is always a bit of drag in the transmission that will transmit to the rear wheels if there is no resistance to them. I hope this makes sense. At any rate, my truck will do the same.
mishkaya
Old Feb 21, 2009 | 12:31 PM
This is a 5 speed I assume? Not a problem.
Old Feb 22, 2009 | 10:43 AM
XCLR8N's Avatar
No this was is an auto tranny. I called around and was told that was normal as the clutches in the tranny have such a small tollerance between them.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
