heating problems
Old Dec 7, 2018 | 02:18 PM
jmw642's Avatar
heating problems
1994 dodge 2500 Cummings has never heated very well in cold weather 20 degree and colder.this engine has a small hose bypassing the thermostat could this be why I have little heat and why is it there to begin with.
Old Dec 7, 2018 | 02:26 PM
edwinsmith's Avatar
Your thermostat could be stuck or non-existent. Unfortunately there are a lot of idiots who take out their thermostat to make the engine run cooler. This hurts performance and mileage.
Old Dec 7, 2018 | 02:55 PM
jmw642's Avatar
have changed the thermo 3 times and even got one from the factory and had no change also block off the radiator at 20 degrees and colder
Old Dec 7, 2018 | 03:00 PM
edwinsmith's Avatar
Can you post a pic of this bypass hose you speak of? I need to see where it goes.
Old Dec 7, 2018 | 05:08 PM
jmw642's Avatar
the hose is right at the thermostat just below the income to thermostat and right above the thermostat the hose is about 3 inches long
Old Dec 7, 2018 | 11:30 PM
edwinsmith's Avatar
Is it connected to a tube that runs toward the back of the engine? If so that is the heater line.
Old Dec 8, 2018 | 02:03 AM
I have one of those thermostat housings as a spare and believe it is just to allow a little bit of warm water to bypass the T-stat before it opens so you can start to get a bit of heat.....so I highly doubt that is the reason for your problem.
Sounds like a problem I had many years ago on my 1st gen crewcab conversion. I was getting little to no heat, tried several different T-stats and the problem still persisted. I eventually figured out what the problem was.....turned out I had lost the vacuum source to the shut off valve on the heater hose inlet line to the HVAC box, it closes off the coolant flow when the A/C is turned on, so the AC works a little more efficiently. I hooked up the vacuum source and my heat started working like an oven again. So perhaps your shut off valve....is you have one on a 2nd Gen...is no longer functioning properly.
Old Dec 8, 2018 | 09:57 AM
jmw642's Avatar
heat problem
no the hose is just on the water jacket. ordered the truck new in 94 its a strait stick and has no air conditioning so would it still have the vacuum hose
Old Dec 9, 2018 | 09:01 PM
BHD's Avatar
BHD
Does the engine temp gauge run in the correct range? Is the engine getting warm, but no heat in the cab? Is this a recent problem or since the truck was new?
Old Dec 10, 2018 | 10:42 AM
jmw642's Avatar
heat problem
no the heat stays down around 145
Old Dec 10, 2018 | 04:18 PM
edwinsmith's Avatar
It's possible the thermostat is defective. You can take it out and test it in a pan of hot water with a thermometer. It should be fully open at 195 deg. If it opens sooner then that's the source of your problem. With a lot of the parts now coming from China I'm always suspect that even new parts are mismarked or just plain crappy quality.
Edwin
DJ Turbo.
Oct 13, 2011 09:11 PM
01'RollinCoal
Nov 25, 2010 07:28 AM
simonswb6
Aug 27, 2003 05:21 AM
KC
Jan 14, 2003 06:30 AM
