Headlight and running light problem
I have a 1993 d350 and the when I turn on the headlights the running lights won't turn on with them nor will they turn on when I pull the switch to the first notch witch should be the only the running lights. I can tweet the **** a little and get the running lights to work but if I hit a bump or barley touch the **** they will go off. It seems like it would be in the switch that seems like the only logical explanation but I've bought 3 different switches 3 different brands from 3 different stores. PLEASE HELP
Have you checked the plug on the headlight switch? Those connectors can get loose and make intermittent connection. Also check the fusible links on the left fender and the fuse panel. I took my switch out of the circuit completely and replaced it with 2 toggle switches. I also have relays for the high-power headlights I have to take the load off the hi/lo switch in the steering column.
You just trace which wire goes where and wire them up. I ran the hot wire to both switches then one switch goes to the headlights and the other goes to the tail/marker lights. I kept the rheostat in the original switch to control the dash lights.
I'm with Mr. Smith. All of these first gens are hard on the head light switch in the headlight circuit. The 1 tons are also hard on them because of the extra clearance and marker lamps on the tail light contacts.
Seems weird that you'd have the same symptoms with different new switches, unless they all came from the same bad batch.
If you can approach the problem with a meter or test light and a diagram when the tail lights are failing, you should be able to pinpoint the failure.
The exactly the same thing is happening to me. No running lights with headlights.BTW my headlights are on relays.
I change the headlight switch and it didn't help. Check grounds,connections
and fuses, nothing worked. Smashed my 2nd favorite coffee mug. Still
didn't work.
I'm going to pull the #14 LG/WH (L20) off headlight stud P and put it on a relay with the accessory switch. This way when the truck is off and I forget to turn the switch off the running lights wont kill my battery.
This should work?
didn't work.
This should work?
didn't work.
This should work?
didn't work.
This should work?
I just had this problem, it was the horn fuse. Park lights would not work on the park light setting on the head light switch. They would come on in a sweet spot past the park light setting on the head light switch but would not stay on when the head lights were on. When I bought an aftermarket head light switch they would not come on at all. I chased this for 2 months.
mtdoragary
Nov 7, 2013 08:31 AM
Joey-D
Dec 12, 2011 12:52 PM
480Ruger
Oct 23, 2008 11:28 PM
jlipskoc
Oct 24, 2005 01:16 PM
first4age
Sep 7, 2005 11:28 PM
