headbolt torque...please
my cummins b manual says to tighten all the headfasteners to 102 fbs... does that sound right..it "actually" says to tighten to 66 fb then turn 90 deg..and "if you cant" rotate 90deg,.. tighten all fasteners to 102 fb..this was a hugh job and I want to make sure I get this part right...thanks
So Dave, do you know what the "FINAL TORQUE" is AFTER the 90 deg turn....and seeing as how were torquing the long bolts to 89 and the short ones to 66...and then turning BOTH and extra 90 deg.. it seems as though the long bolts are being torqued to a higher foot lb than the short bolts...is that correct?? Does anyone know what the FOOT lb is after the 90 deg turn..and are they ALL the same foot lb or are the the long bolts torqued to a higher foot lb...I'm
Neither of my books say anything about what the final torque will be, just that you need to torque 'em then go another 1/4 turn.
The long bolts will end up being torqued to a higher value. This is because a longer bolt (all else being equal) is more elastic, so to get the same clamping load you must apply more torque.
TheProspector
Nov 30, 2012 06:27 PM
oldblues
May 27, 2007 10:39 PM
