valve adjustment / headbolt torque ?
Old May 25, 2007 | 12:04 PM
oldblues's Avatar
Question valve adjustment / headbolt torque ?
hi
can some one please look up the head bolt torque for a 1998 12 ?
also the torque for the valve adjuster locknuts ?
thank you !
Old May 25, 2007 | 01:20 PM
Chrisreyn's Avatar
Valve lock nuts are 18 flb... beleive the vavlve covers are the same
Old May 26, 2007 | 09:45 PM
dpuckett's Avatar
On my 92, I retorqued the bolts to 125ft-lbs, as per instructions from Joe Donnelley.
Daniel
Old May 27, 2007 | 11:12 AM
clutch1's Avatar
are you just retourqing or new hg? cant remember exactly but its something like 65 first then you end up at 90 and then go 1 1/2 flats.
Old May 27, 2007 | 01:17 PM
cheapskate's Avatar
i have my doubts about the whole re-torqueing of the stock head bolt, due to the fact that they are stretch bolts. when installing new head bolts it goes 65 ft/lbs, 90 ft/lbs, then an additional 90 degree turn on each (following the correct pattern). the 90 deg. turn stretchs the bolts, so who knows what the final torque is? i would think that re-torqueing or any tightening afterwards would simpley stretch the bolts more than they were intended to, possible causing one to fail. it can happen. a broken head bolt caused me to recently have to install a new head gasket, i never re-torqued them, it just broke all on its own. maybe someone else screwed with them? inthe pic, you can see where the broken head bolt caused the head gasket to fail.
Attached Thumbnails valve adjustment / headbolt torque ?-s5001296.jpg
Old May 27, 2007 | 10:39 PM
dieseldemon's Avatar
Cummins spec. is 60 psi for the short and intermeditate bolts and 90 psi for the long bolts then 90 Deg for all when I do them I torque them all to 120 psi then retorque them at 50.000 back to 120 psi.
TheProspector
Nov 30, 2012 06:27 PM
pulltilbroke
Sep 8, 2010 12:50 AM
schamran
Aug 30, 2010 07:14 PM
CrewCabCummins
Nov 8, 2005 06:08 PM
Dufrain
16
Mar 1, 2005 12:51 PM
