How to Reset Trouble Codes???
Old May 9, 2007 | 09:29 PM
Muskys TD's Avatar
I have a 95 ram 2500 and for some reason my "ABS" light and "Parking Brake" light stay on. I believe 1 of 2 reasons my have caused this.
1) I recently removed my front caliper and rear drum to inspect my brakes
or
2) I drove over a really big pot hole.
I didn't notice the warning lights after I inspected the brakes, but I wasn't really paying attention. The next morning on the way to work I ran over a really big pot hole and that's when I noticed the warning lights.
Does anybody know how to reset these trouble codes so I can see if they will come on again???
Old May 9, 2007 | 10:16 PM
bob4x4's Avatar
There is no resetting for the abs light,when the problem does not exist the light will go out.Most likely cause is the rear speed senso in the diff has failed as long as you did not hurt any wiring or sensors while working on the truck
Bob
Old May 27, 2007 | 11:44 PM
dieseldemon's Avatar
A vacuum leak will cause the ABS light and the Brake light to stay on also
Old May 28, 2007 | 11:49 AM
infidel's Avatar
Brake codes are what is known as a hard code, they have to be reset with a code reader or wait for 60 engine on/off cycles without the problem present to reset. This is to insure that the owner takes care of an all important brake problem.
roynr
May 7, 2007 07:32 PM
zulusafari
Aug 22, 2004 05:55 PM
rmb93243
Jul 9, 2004 12:51 AM
2500CTD
May 24, 2004 10:31 PM
jt
Nov 17, 2003 05:26 PM
