Head Bolt Torque
Old Jan 23, 2018 | 05:46 AM
Jim Lane's Avatar
Head Bolt Torque
How to torque Head Bolts for 1991 4BT & 6BT engines.
This was sent to me by a Cummins Technician,
I would take this as being accurate.
This is specific to my 1991
Jim
Old Jan 23, 2018 | 07:24 AM
nonrev's Avatar
Super Moderator
10 Year Member
So if I'm reading this right you tighten them all in sequence to 66 ft-lbs, then tighten the 6 long bolts to 89 ft-lbs, then run through re-torque the 20 short bolts to 66 ft-lbs, then the 6 long bolts to 89 ft-lbs.
Now you go through and mark your head, the bolt and your socket so you can give them all a 90 degree turn in sequence. Would you follow the same procedure if you were running studs?
Old Jan 23, 2018 | 02:17 PM
deere country's Avatar
If you had head studs you should follow the procedure of the manufacturer of the studs as it's likely not the same.
Old Jan 24, 2018 | 04:39 AM
Jim Lane's Avatar
Yes,
You can follow along how I torqued the head in this post.
https://www.dieseltruckresource.com/...-329169/page5/
Jim
inline6power
May 12, 2006 07:56 PM
White00
Feb 28, 2006 02:03 PM
fordsux8269
Jan 2, 2006 01:25 PM
Beerrunz
May 31, 2005 04:06 PM
figure_9_pro
Jun 26, 2003 08:24 PM
