Having troubles with my starwheel...
Old Jan 6, 2006 | 05:56 PM
NoSparkplugs's Avatar
I tried adjusting my starwheel today and its not turning as easy as I thought it would. I tried everything from using a flathead screwdriver and tapping it with a hammer to pushing it with the flathead. I barely moved it and all I really did was chew the teeth up a bit. I stopped before I did anymore damage and put it back together.
Is there some sort of trick to doing this? Or am I just not trying hard enough?
Thanks
Lucas
Old Jan 6, 2006 | 06:10 PM
How far down is it? When they are really low you can see about 1/4" of threads showing on the center tube.
Old Jan 6, 2006 | 06:14 PM
I didn't measure but I saw quite a few threads exposed. Maybe somebody was in there before me?
Old Jan 6, 2006 | 06:32 PM
bgilbert's Avatar
It's probly already all the way down. If you want more low end smoke, just remove the starwheel. That will gain you a little more travel.
Old Jan 6, 2006 | 11:45 PM
Underpsi's Avatar
wouldn't removing the spring have the same effect?
Old Jan 7, 2006 | 11:01 AM
bgilbert's Avatar
Yes it would. I am one that likes it there though. In my mind 220rwhp and a smoke show is not cool. It doesn't take much to get a ton of smoke, especially low boost black out the highway smoke. Do it at WOT, then thats a little more . WOT and a big turbo, then yes, .
pittom
Jun 7, 2005 02:43 AM
Richard William
Dec 4, 2004 11:44 PM
jprovence
22
Oct 14, 2004 02:54 PM
luie
Aug 20, 2003 10:36 AM
cummingetit
16
May 17, 2003 03:38 PM
