Have you seen this????
if so what did you do or what was it??
I am leaving for a road trip fill up the tank, forget something, drive back maybe 5miles, turn back around, head out goin up a hill. kerplunk kerplunk, loss of power engine wont run in 5th put it in a low gear, it started jerking like power was on and off. To me it felt like fuel cut out? what you guys think.
Shutdown solenoid???? where might i find that.. Remember guys i am a gasoline engine tech and this would be my first diesel engine so i need to locate the major components on this baby...
There's a wire going to a solenoid almost directly above where the high pressure injection lines come out of the pump...actually, on your 93, there may be two wires going to that solenoid. In any event, they are just crimp-on female spade connectors. Sometimes the wire breaks loose of the spade, sometimes the whole thing slips off the solenoid due to a tired out spade. FYI, there's also a cold advance solenoid on the side of the pump closest to the driver-side fenderwell...that's not the one you're looking for.
Hope this helps!
Greg
Hope this helps!
Greg
Hope this helps!
Greg
Hope this helps!
Greg
more than a couple of drips should come out of the fuel filter if you open that bottom valve, either the filter is clogged or the fuel pump went out, although thats seems unlikley it is possible.
