Has anyone here ever outrun a LP piston lift pump?
Old Apr 30, 2011 | 08:55 PM
bgilbert's Avatar
At one time I ran the 3936320 low psi pump with stock lines and filter, it would suck down to zero. That's with 14mm and Scheid 6x16's. For a dyno run however, it still put down 443rwhp. Went to the A1000, 5/8" line, big filter, regulator and gained 7rwhp with no other changes.
Old Apr 30, 2011 | 09:17 PM
mhuppertz's Avatar
I'm scared to rely on an electric pump only. But I admit I drooled over the A1000 when I looked it up.
I have a gasser sending unit with pump, and was kicking around the idea of running that with a regulator up to my piston pump. Don't know if I can find a regulator that can deal with the pressure of a gasser electric pump.
Old Apr 30, 2011 | 09:31 PM
mhuppertz's Avatar
I was thinking about this...
http://www.turbodieselregister.com/f...sher-pump.html
Old Apr 30, 2011 | 09:34 PM
The_Head's Avatar
Well, sounds like I really need to get my fuel pressure gauge hooked up to really be sure.
Old Apr 30, 2011 | 09:56 PM
BILTIT's Avatar
Thats why i will have a spare electric, quick to swap out if there is problems with the first one and they can be found cheap.
Old Apr 30, 2011 | 10:18 PM
ARbowhunter7's Avatar
I wouldn't buy an AD or a FASS. I'm not into paying that much for a pump just because somebody CNC'd a billet block that the pump sits in. Bottom line is, 500 bucks for a 15 psi fuel pump is insane, IMO. It's other "benefits" are debated in the 12v world.
Spend the dough on a big-dog A1000 and an Aeromotive regulator. Throw a NAPA 4772 head w/ a Cat 2 micron filter in front of it, and you're ready for any mod you could ever want.
Old Apr 30, 2011 | 10:27 PM
BC847's Avatar
1st Generation Admin
Originally Posted by The_Head
What are you running now? I was thinking about an Airdog 100 or 150 for a 24 valve application. I think I remember reading they are regulated to the same pressure as what out injection pump needs.
I'm currently running a Walbro 392, with an Aeromotive bypass type regulator. 3/8"ID supply with a 1/2" return. Schide 6x.016 EDMs and a stock/OEM 12mm VE (cept for the usual stuff). At the top of a 12.81 quarter mile pass, it's down to 16psig or so. 440HP/1000ft/lbs (+/-)
Old Apr 30, 2011 | 10:30 PM
mhuppertz's Avatar
That's insane power for a stock pump.
Jasonbailey
May 11, 2011 10:52 PM
roxxx
Oct 18, 2010 10:53 AM
Timberman
Competition / Pulls / OffRoad
45
Apr 2, 2007 09:16 AM
abc4yew
44
Mar 9, 2006 01:40 PM
thumper 549
Sep 25, 2003 02:01 PM
