hard starting
hard starting
I am repairing a truck and cant figure out why the fuel filter is half full. installed new lift pump. Read as much as i could find in this forum and a air leak was the cause. I ran a clear line from the tank to lift pump and there were very small bubbles running through the line. Can this cause my problem also the injection pump goes dry. i.e. fuel line from filter to inj. pump removed no fuel comes out of either end. I checked vacuum lowest was -4.5 in third gear and full throttle up hill. Is the spec of -4 at idle or full no load or full load? any help would be appreciated. p.s. the air bubbles that other guys have found coming from the tank, can you describe how much air was actually entering? thank you.
fourthandgoal
88
Dec 27, 2011 05:39 AM
abc4yew
Mar 15, 2007 11:55 PM
