Hard to start after sitting without slight throttle applied
1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
Recently my 1991.5 d350 cranked more than the usual bump and fire on cold start. After initial start it restarts fine. The truck is stock with the pump being rebuilt by Shield diesel in 2005 with less than 3 thousand miles since, stock lift pump replaced at the same time. The fuel filter was replaced in the spring and again after the odd start. The only leak comes from the top of the fuel tank if completely full but doesn't leak by fuel movement while driving on the winding roads in the middle of nowhere Appalachian mountains. I found if I slightly press the accelerator pedal it fires right off and idles fine. Any help would be appreciated before I take it to a shop. My plan was to have a Fleece sure flow unit put in the tank along with a high volume mechanical lift pump but would like to get the starting issue resolved first....Thanks for any knowledge
Usually when these start hard after sitting overnight you have a leak in your fuel lines and it is normally before the lift pump. I have used an old fuel cap and installed a male chuck in it to pressurize the tank (not over 10 lbs) give it a few minuets and inspect your lines from the fuel tank forward and you will normally find it. Pic of the cap I made, hope it helps.
The link is for gas trucks 20 gallon tank mine is 30 gallon diesel
Well dog my cats!
Have you dropped the tank? It's very simple assembly. Change out the o-rings inside and on the quick disconnects. It's been a couple of years since I pulled mine out. I can't remember if there is O-rings inside it. I pulled the whole assembly and replace it with a Carter in tank pump.
I had the same tank leak on my 91.5. Turned out the collar ring was loose. All it took was tightening it up.
As for hard to start, I have a similar issue but not quite. Mine gets worse only if it is a hot day and I'm doing a lot of shut down and restart driving going place to place. Sitting doesn't bother it. I do have a leak at the back of the engine. Not sure where yet. I will need to enlist someone that's not old, fat, and crippled to get back there.
I have a cheap Amazon endoscope to poke around in dark places. Problem is, it is so oily back there I can't pinpoint it. I'm trying to get my hands on a hotsy and do a good stream clean.
Thanks for the link sir. It is also hard for me to start after sitting without slight throttle applied and I don't know why. But I am glad I found my solution over here. It's wonderful how the chance led me to your post while searching for online essay writing help, I discovered a link, a website that efficiently aids in completing essay assignments. If you also need help then you can try these out It's impressive how quickly this resource has helped me accomplish my tasks.
