Grid Heater wire repair
Old Nov 13, 2011 | 07:48 AM
Since I have a "cold start" issue unless I plug my truck in every night, I'm in the process of repairing .... or attempting to repair my grid heaters.
I now realize that someone jiggered up my wire on my grid heater and it's supposed to look like the pic of my former cummins dodge.
Can I fabricate a wire of the same gauge and length and install, or is the wire special to the grid heaters ????
Thought I would buy a wire of the same gauge shorten it, and add new copper ends to it... Torching them & lead soldering the ends
Nearest cummins supplier is in Newark.
BTW,
This is from the sticky, and looks like a good start to maintenance.
http://dens-site.net/Dodge_CTD/Grid_Heater_Relays/
TIA
Old Nov 13, 2011 | 08:27 AM
twichit's Avatar
As far as i know there is nothing special about it. Its a ground so it should be fine with plain old wire
Old Nov 13, 2011 | 12:56 PM
jimbo486's Avatar
Just as lil dennis said, it's a simple ground wire. Match the gauge and length of the stocker as you mentioned with the proper terminals on either end and ground it.
In the first picture, is it just me or is the terminal is soldered to the intake elbow rather than under the bolt?
Old Nov 13, 2011 | 03:03 PM
BILTIT's Avatar
It is soldered to an eyelet connector which is under the bolt, hard to see though.
Old Nov 13, 2011 | 03:48 PM
jimbo486's Avatar
Oh, I see it now.
Old Nov 13, 2011 | 04:47 PM
BigIron70's Avatar
Cummins Guru
If you replace the two intake gastkets you can do away with the ground wire. The new gastkets are conductive while the old ones weren't. The heater grid is grounded to the housing.
Old Nov 13, 2011 | 04:51 PM
Where can I order them ?
Sounds like a good idea.
BTW,
I found out what the P.O. had done.
The terminal (top) broke off of the bolt post, and instead of replacing the wire with a new one, he took a #12 wire from a romex cable (used in houses world wide), cut a short section of it, wrapped one end around the broken end of the wire just below the sheared hoop, and wrapped the upper end around the bolt and tightened it down.
Couldn't figure out what it was until I actually removed it..
Old Nov 14, 2011 | 01:09 AM
BigIron70's Avatar
Cummins Guru
Dealership or Cummins should have them.
Old Nov 14, 2011 | 06:57 AM
twichit's Avatar
id go into napa and make one
Old Nov 14, 2011 | 07:21 PM
Made one today.
Here's the P.O's attempt at fixing the wire:
And my new wire which I made from a piece of 4 gauge and a new copper end from Advanced.
I burred the inside, filled it full of flux, added solder, and made a new wire.
Cost me $8.00
I spent about an hour, following the sticky with reference to "rebuilding or maintaining" my grid heater solenoids. Well worth the time.
I cleaned the internals, and checked for proper function by using a test lead and a couple of wires off of my battery. Each solenoid works like new. Now all i need is a really cold day, and I can see if I'm working or not.
Darn warm weather. I need to make some money....
Please let it snow..... PLEASE !
T.
Old Nov 14, 2011 | 08:29 PM
jimbo486's Avatar
Great job, T!
Old Nov 14, 2011 | 08:37 PM
DevilzTower's Avatar
new wire looks purty!
Ramrod90
Feb 3, 2009 07:39 AM
DmaxEter
Jan 21, 2007 03:38 PM
taildragger
Dec 4, 2006 10:00 AM
highboyrancher
Jan 21, 2004 05:37 PM
TPilaske
16
Nov 22, 2002 08:15 PM
