Grease conversion on a '92 CTD
I didn't know or think of a ramcharger tank. that is a good idea wanna
the fill neck will be at a 45 degree angle on the top back corner. hope to have that done tomorrow or next day..I will keep this updated with pics of filler tube location etc.. for the most part you will not know I am running grease if you drive by me.. no tank sticking up in bed of truck and no extra filler tube on side of bed
"for the most part you will not know I am running grease if you drive by me.. no tank sticking up in bed of truck and no extra filler tube on side of bed"
Hmmm, you don't think the overwhelming smell of french fries and fried onion rings with no restaurants within 20 miles will give it away?
I converted my 93 1ton to svo and I love it. Runs smoother and quieter on the stuff. I used a Hotfox in tank heater, a Vormax heated fuel filter/water separator, an additional electric fuel pump and a Vegtherm Mega in line electric heater. I would seriously consider the Hotfox for your tank since your coolant setup requires you to heat the whole tank up before switching over to veggie, the Hotfox will let you do it sooner. My tank is a steel 60 gallon, I don't think rust is an issue at all and I wouldn't coat the inside of yours (I seen alot of the tank coatings peel and clog filters) since it is important to dewater the SVO anyways. It is oil and the last time I checked oil is a good rust preventer (it's what they coat raw steel with).
Forty-Two
10-22-2008 11:55 PM
