gov spring
Old Apr 22, 2007 | 07:47 PM
enydick's Avatar
gov spring
today i put in my 4000 gov spring and in 4 th gear the truck kind of falls on its face does any one have an idea what is wrong
Old Apr 22, 2007 | 07:52 PM
Sounds like you got the throttle shaft indexed wrong.
If you are running a 4200 RPM spring it needs to be trimmed to length. What is the 3 digit code on your spring (last 3 digits of the part number)?
Old Apr 22, 2007 | 08:33 PM
gman07's Avatar
Also if you plan on running over ~3400RPM, you should put in 60lb valve springs to prevent valve float.
Old Apr 22, 2007 | 08:38 PM
enydick's Avatar
gov spring
i ordered it from pdr the part number is 354
Old Apr 22, 2007 | 09:07 PM
enydick's Avatar
if it were the throttle index would it still rev ok in neutral or could it be the fuel filter clogged
Old Apr 23, 2007 | 04:15 PM
If it's indexed wrong it will be boggy if it runs at all.
Did you trim it so it's the same length as stock? If not then that is your problem. Pull it back out an redo on of the ends so it's the same overall length as the stocker.
Old Apr 24, 2007 | 10:07 AM
enydick's Avatar
it s fixed i tried a fuel filter and that did the trick thancks for all your help
fishin fever
Mar 13, 2006 06:46 PM
Bushy
Apr 13, 2003 04:09 PM
Jim Shulmister
Mar 8, 2003 09:07 AM
NeedMoPower
Feb 17, 2003 01:00 AM
boehunter49
39
Jan 12, 2003 06:19 PM
