lowering the tail of a 4x4
Old Apr 23, 2007 | 03:44 PM
ponygallery's Avatar
I'm new to the forum and a new owner of a 91 2500 quad cab 4x4 with the factory towing package and camper package (overload springs and sway bar). I'm courious to see if anyone has taken an inch or two out of the back end of one of theese. I drop and hook loaded livestock trailers and some of the goose necks are a bit rusty and don't raise and lower easily. This truck will never leave the pavement so I don't really care about ground clearance.
Thanks for the feedback
Cowboy
Old Apr 23, 2007 | 03:49 PM
dieselfuelonly's Avatar
DTR question asker
Hey do a search for "leveling kits". Should bring up a lot of info. Just be careful that you don't get it completely level, or it might sag with the trailer on.
Old Apr 23, 2007 | 03:50 PM
SIXSLUG's Avatar
An old guy on my street has dug two furrows in the ground under his 5'th wheel so he can get his rig coupled easier but it doesn't sound like this will help in your case. I'd imagine to do it correctly you would have to re-arc the spring packs to take some arch out of them.
Old Apr 23, 2007 | 09:27 PM
alborada's Avatar
Seems you could just get blocks that are a bit shorter to replace the factory ones. The factory block has the bump stops built into them so you would have to come up with something diff. If you don't have a dent in your exhaust pipe yet you will after you lower it.
Old Apr 23, 2007 | 09:57 PM
rustbucket's Avatar
just find a set of shorter blocks,I used a set off of a f250 ,had to do a little grinding to make them fit,but now it sets level,and is a lot easier to get trailer hooked
Old Apr 23, 2007 | 10:14 PM
bimmerboy86's Avatar
trade ya my sagged rear springs, haha
Old Apr 24, 2007 | 12:17 PM
93beater's Avatar
im not sure about yours, but my truck has about a 4 inch lift kinda looknig block under the leafs, it is stock, maybe if yours has that you could get some smaller blocks, or just simply pull a leaf??!!
nasty01cummims
Jun 30, 2009 01:52 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
jarmar
Jul 4, 2004 11:51 PM
turbospl311
Apr 24, 2003 07:46 AM
Chester
Feb 28, 2003 07:59 AM
