Is it the Getrag,transcase or diff ?
I need some help in figuring out where the howling is coming from. In the last month I been getting a howling from under the truck.I don't think its the getrag sounds more like its coming from the transcase or the rear diff.The noise is the worst when I let off on the throttle and unload the driveline or if I put it neutral and coast.I changed all the driveline fluids in the spring and had milky rear diff oil so maybe a bearing problem there??The rear output shaft on the transcase has a little play in it so maybe a bearing there needs replacing?? Any ideas on where to start without just chasing the problem around changing stuff and still having the noise?
Thanks Andrew
Thanks Andrew
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
