Help!! What Happened
Old Sep 25, 2007 | 09:46 AM
flyingd's Avatar
It just quit in the middle of the road.
I was driving down the road and it just died. The peddle went flat like the linkage fell apart. After I slowed down a ways the peddle came back up.
It stopped where there was no way to get off the road. It is two lane and it was fun. The wife steered and I pushed it up hill to a turn out, about 150 ft of pushing, took me three tries to get it there. That was hard.
Anyway it would not start and I had to call a tow truck. All it would do is crank over. When we got home, for fun I cranked it over again and it started. I found the banjo bolt going into the injection pump just on hand tight. I tighted it with a wrench and it seems alright. Still smell a little diesel and it seems a little wet around the lift pump.
Please give me ideas.
Thanks
Old Sep 25, 2007 | 10:40 AM
Chrisreyn's Avatar
Possibly sucked an air bubble into the pump through the loose banjo?
Clean the pump and fuel lines off and see if you have a leak. It might be your lift pump , but if it was running, the IP should have pulled fuel even if the lift pump quit, unless the IP is weak also...
Old Sep 25, 2007 | 01:28 PM
Micaiahfied's Avatar
also make sure the shut down solenoid is SECURELY connected. a while back one of mine would sputter and try to quit when i floored it... i thought of tons of posibilities, turns out the wire was loose and when i floored it the movement of the motor dis-connected it! make sure that thing is on there good!
admin
38
Nov 12, 2002 03:26 PM
DarrellB
Nov 9, 2002 10:09 PM
cr1998
Nov 2, 2002 10:43 PM
Huey
Oct 11, 2002 07:41 PM
