Getrag trans cooler ??
Old Dec 16, 2005 | 08:33 PM
tboling's Avatar
I'm thinking of putting on a transmission cooler of some kind on my getrag. Have any of u given this a shot?? Thanks Tboling My getrag got to hot an burned out a bearing so I'am looking for a way to keep cool
Old Dec 16, 2005 | 08:39 PM
G1625S's Avatar
PM Needmopower about his. He claims temps under 200 pulling cars over the Rockies! I hit 230 running empty! I plan on using an under bed tranny cooler with an electric pump fed from the drainplug, then returning though the fill plug. She gets hot, I flip the switch, but if the system fails to operate, I can still operate the truck.
Old Dec 16, 2005 | 08:44 PM
tboling's Avatar
I'm thinking of making to holes in the trans case why I have it out an thread them. An use a small pump to keep the oil in flow. What do u think about it G1625s??
Old Dec 16, 2005 | 08:56 PM
G1625S's Avatar
Are you talking about the 205? You could run sand fresh from the desert in a 205 and it probably wouldn't break
Old Dec 16, 2005 | 09:17 PM
I think it's mopar2ya who has the home-brew trans cooler. You can also get the parts to do it from a company that deals with oval track and road racing transmissions. It's definitely a good idea on a hard working transmission.
Old Dec 16, 2005 | 10:04 PM
BearKiller's Avatar
Getrags will get smoking hot when pulling 15 big 1600 pound cows and a 28x8 (floor length) gooseneck.
I have seen them almost red with heat.
I definitely have a cooler for mine on the drawing board, along with a recirculating pump.
My opinion is that the light oil is to blame for the Getrags problems.
Old Dec 17, 2005 | 06:59 AM
G1625S's Avatar
''I think it's mopar2ya who has the home-brew trans cooler''
Thanks Dave, I knew the word ''mopar'' was in there somewhere...
Old Dec 17, 2005 | 01:48 PM
tboling's Avatar
I sould of made my self more clear I mean that the holes are going to be drilled in the getrag transmission case. I belive the problems with the getrag over heating is the lack of oil and to small of bearings on the cluster shaft . If the case was larger and the bearing made biger the old getrag would never have failed. I would like to hear more on the mopar trans cooler so please go on. THANKS TBOLING
Old Dec 17, 2005 | 01:56 PM
I think Greg's plan of using the drain and fill holes is fine and would work well on a 4X4. I'd be a little nervous about knocking off the bottom fitting on a 2wd. If you want to drill holes in the case, line up the return so it dumps on 5th gear.
Old Dec 17, 2005 | 03:45 PM
hippie's Avatar
What pump would be good to operate under that heat that is low pressure and low volume? Right now I have two heats sinks mounted where the PTO covers go. I also want to be able to pump the hot oil thru a filter then thru a cooler. I have switch to the NV5600 but I like the over kill idea. I have seen it get up to 215* but no higher. I want to keep it under 200*. If anyone knows of a pump thet runs on 12v DC that is low volume and low pressure please let me know. Thanks.
Old Dec 17, 2005 | 05:24 PM
BearKiller's Avatar
Those 12-volt agricultural spray pumps can be bought by themselves, without having to buy the whole spray unit.
I have heard of them being used in this application.
Northern Tool, FarmTek, Tractor Supply, etc. should carry these.
Old Dec 17, 2005 | 06:53 PM
Grey Wolf's Avatar
I'm using a Fast Cooler on mine, I tow my trailer and I'm using the original Getrag trans not rebuilt.....yet [IMG][/IMG]
Old Dec 17, 2005 | 06:54 PM
hippie's Avatar
GW, That looks like the one I have...
Old Dec 18, 2005 | 01:51 PM
tboling's Avatar
Were can I buy one of these coolers?? I like the fact that it bolts right on the pto cover hole and how much green will it cost me? Thanks TBOLING
Old Dec 19, 2005 | 08:49 AM
SilverZuk's Avatar
Why we are the topic, what type and weight of oil are you guys using?
Also, how many quarts does it take with over filling?
Here is a link to fastcoolers:
http://www.fastcoolers.com
$189 for the getrag.
How does oil circulate through the cooler?
