getrag trans cooler ?
Old Mar 22, 2010 | 11:26 PM
dheffel's Avatar
Can this cooler be used with getrag. It says for new venture only but it looks like what others are using.
http://3rdstrike.biz/cart/index.php?...63b3c0eba7f6f9
Old Mar 22, 2010 | 11:27 PM
schamran's Avatar
It doesn't look like it will clear the bolts that hold the trans to the bell housing, but don't quote me. It should be the same bolt pattern.
Old Mar 22, 2010 | 11:31 PM
schamran's Avatar
According to Genosgarage, the coolers you are looking at will only fit New Venture Transmissions. They often leave out first gens, however. This will fit your getrag: http://www.genosgarage.com/prodinfo....er=TRANSCOOL_1
Good luck.
Old Mar 22, 2010 | 11:34 PM
dheffel's Avatar
I know but thats a big difference in price. Plus they dont appear much different in bolt location/cooler size.
Old Mar 23, 2010 | 02:11 AM
PapeCAT's Avatar
Oh don't let the rhetoric fool you, I had to dremel/grind my "Trans-COOLS" from genos to fit the getrag! NOT the fit you'd expect from a part @ that price...
I'm sure the cheapies will fit, you will just need to grind em.
Old Mar 23, 2010 | 08:06 AM
DaveCFF10's Avatar
Someone suggested using an auxiliary electric pump and a regular tube and fin type cooler, that's what I want to put on my truck, but I haven't been able to find a pump I want to use. Tilton makes a $200 unit but I'm told it is horribly loud. Does anyone have any better solutions?
nvr-enuf
May 10, 2011 02:49 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
tboling
Dec 19, 2005 11:38 AM
live wire
Jul 21, 2003 07:26 AM
