Getrag Temp???
Old Jan 8, 2005 | 02:25 AM
hippie's Avatar
Getrag Temp???
How hot is to hot for a getrag... I've seen mine get up to 230*. That's pulling my 5er on a good hill with a 35 MPH head wind.. I also put an extra quart of oil in...
Old Jan 8, 2005 | 05:53 AM
230 is an acceptable temp for the oil, but the trans would probably be happier down around 200 degrees. Mopar2ya (the million mile guy) added a cooler to his Getrag. Companies that sell circle track racing parts can get you the parts needed to do this, they use them to make rearend coolers. All you need is a pump, oil lines, and a cooler. If you want to make it automatic add a temp switch in there. Your PTO covers are gonna be covered with plumbing now...
Old Jan 8, 2005 | 10:08 AM
mopar2ya's Avatar
I got a shur flo pump I can get you the part number if you want and a cooler (dodge minivan a/c condenser ) and a couple of fittings and hose. The pump mounts on my tranny crossmember and the cooler is between the body and frame. I also put a temp gauge and thermal switch in the PTO cover. Its a 180 degree switch w/ manual if I want.
Be sure to mount the pump on the outlet/discharge side of the cooler so you get the cooler oil pumped through the pump. I can keep the tranny temps under 140 on hot days pulling in 5th grossing 26K, so it works really well.
The PTO fitting are located low and high on the cover, pull the oil from low and pump it back in on the higher fitting.
Old Jan 8, 2005 | 11:19 AM
charger 69's Avatar
Do you think an electric fuel pump would move hot gear oil as I have thought about using a similar setup for the rear end with one of those fan mounted coolers from Summit Racing?
Old Jan 8, 2005 | 12:12 PM
hippie's Avatar
Kewl, I was thinking about doing something like that but wasn't sure which to go. Thanks... I'll start lookinh into getting sety up...
Old Jan 8, 2005 | 04:11 PM
hippie's Avatar
if you can, give me the part numbers and where you found the temp switch and pump.. I have a holly red but I don't know if it will take the heat of the oil. Thanks Hippie...
Old Jan 8, 2005 | 11:13 PM
mopar2ya's Avatar
Its not set up to handle the heat, at least according to the mfg.
Old Jan 10, 2005 | 01:49 AM
hippie's Avatar
What can't handel the heat,,, the Holly Red...???
cootz
Jan 14, 2011 12:39 AM
ppiggppenn
Aug 4, 2009 09:55 PM
Cowboy_Customs
Apr 11, 2007 05:51 PM
andyr354
Mar 15, 2006 06:57 PM
firesine
Nov 24, 2005 10:58 AM
