getrag shifter
getrag shifter
oh lord this has to sound dumb but how in the heck do you put the shifter together i have the shift fork bushing thingy and a (c) clip that need to go in right what order do they go in (i took this thing apart a month ago) i got it all in the truck and now spent the last hour trying to get this thing in there.....grrr
oh its a 90 if that helps
I f you arent already, you need to compress the shifter down onto the spring below it in the shifter-houseing in order to get the c-clip in.. its easiest with two people, but one can do it if your limber....
so the order is shift fork then the bushing i guess that is what it would be goes on top of the ball on the fork push down and tapin with hammer? i cant get the bushing thing down low enough to get the clip in......
yup its all a custom drag rig tube frame short bed standard cab no p pump the VE has alot of poop to it running a fass with a 1/2 in feeder line and a constant 14psi fule press ported head knifed 7lbs off crank performance cam 90lb springs billet retainers & keepers fluid damper ddp Competitor Series Injectors ats tranny cooler stage 4 W/M Water 2 air I/C twins turning 4200 rpm and i just got the trany back from the shop along with an $2500 bill but they guarantee that it will hold up to 650 hp so its worth it but i cant get this shifter in
um no not yet i just got it done and made a dyno run and 5 passes down the 1/4 in the 16 of january then had trouble got it all back together now (yes allmost a year later)(hey iam slow) and the next runs are jan 22 but i know the guys at the track so we will see if i can sneak out in a coupple weeks and i will get some vids and pics when i go back down there
