getrag problem?
Old Jul 12, 2004 | 03:30 PM
My '93 FSM says preload should be 6 to 8 thousandths for both shafts. Heck, you got it apart, you got the specs, you don' need no steenking manual!
Old Jul 12, 2004 | 06:43 PM
Bill Tomlinson's Avatar
Sounds good to me!!!
I had a little trouble with the last bearing race so I got out my trust grinder and .... it sure made some neat sparks. All is ready to reassemble.
Old Jul 12, 2004 | 08:47 PM
Monty's Avatar
I have heard that you want to go back with the bronze pilot bushing as its wear rate is alot better than the needle type.
Old Jul 12, 2004 | 10:28 PM
My old volvo's used needle bearings. Sometimes when they went they jammed and you went through hell trying to extract the pilot shaft. I bought a bronze one to replace the bronze on that is in it.
Any good ideas for extraction? I suppose I will have to pull the bell housing and the clutch. Good time to look for problems there, although the clutch performs well as long as I don't try to get too fancy.
I guess that the bushing will come out fairly easy. I have found a bolt which is the same diameter, put grease in the hole and hammered the bolt in which shot the bearing out. I have also used a custom bent screwdriver and a smaller bolt to make a puller. I have even used a broken hack-saw blade to cut a couple of slots and make the bushing fall apart.
Old Jul 13, 2004 | 02:35 PM
Alec's Avatar
Sounds as though things are going well!
Good luck finishing her up!
Old Jul 13, 2004 | 10:13 PM
Jim Shulmister's Avatar
Muted User
Bill you have mail.
-Jim-
Old Jul 15, 2004 | 06:20 PM
ARRRGHHHHH!!!!
NAPA supplied the wrong pilot shaft bearing AND the wrong Driveshaft hanger bearing.
THe old pilot shaft bearing looked very healthy and new so I left it in. The transmission I put in by myself so there was an hour of push pull, cuss etc but it went in fine when I got it all lined up properly. No problem with the shifter circlip. Looks kind of pretty down there.
Old Jul 17, 2004 | 08:31 AM
She works!
Shifts very smoothly and has a solid feel. A little low rpm rumble in 4th but better than before and all other gears are quite smooth.
No leaks....
We'll see how she works when I pull the 5th wheel to Minnesota in a couple of days.
Old Jul 17, 2004 | 08:34 AM
Oh yeah. THANKS TO ALL OF YOU
I COULDN'T HAVE DONE THE JOB WITHOUT YOUR VALUABLE HELP
Old Jul 25, 2004 | 08:05 PM
UPDATE
Pulled the 5th wheel to Minnesota. 4th gear no longer vibrates. I guess the new pilot shaft bearing had to seat in to the pilot shaft. I was a little concerned because this was the only bearing that can't have a new seat. It is much quieter in all gears and really quite tight. There are no leaks and I guess I have to declare the fix a real success.
Bill
Old Jul 26, 2004 | 10:49 AM
Alec's Avatar
Good work!
BCDave
Apr 12, 2010 02:35 PM
pridero
Mar 9, 2010 06:46 PM
90firstgen
Jun 23, 2007 10:28 AM
C Pierce
Jan 25, 2005 08:08 AM
AndrewHuey
Nov 2, 2003 08:52 PM
