Getrag issues
Old Jan 12, 2015 | 10:50 PM
  #31
Originally Posted by Alec
TC -- The Getrag bearings are pre-loaded -- so you have to do some math no matter how you measure.
Ahhh I see...fair enough. Thank you for informing me on this.
Old Jan 14, 2015 | 09:42 PM
  #32
thrub's Avatar
I'm glad I ordered a new pilot bushing. The old one was trashed and there were pieces of bushing broke off and laying around the hub of the clutch. On the bright side the clutch looked really good. Still the original Sachs. I checked all the flywheel bolts while I was in there. I had to use a hack saw blade to cut the bushing so I could pull it out. Installed the new bushing and cleaned everything up and got it bolted down again. Hopefully the rest of my parts come tomorrow and I can assemble the mainsheet before I forget how it all came apart. I broke down and ordered a proper depth gauge and it should be here tomorrow too.
Old Jan 14, 2015 | 11:03 PM
  #33
When I did my NV4500 I must have taken 300 pics during dis-assembly....came in handy when re-assembling it.
Seems like things are coming together...keep at it!
Old Jan 16, 2015 | 08:38 AM
  #34
thrub's Avatar
The rest of my parts showed up yesterday and I managed to get the mainshaft together last night. The ***** and springs that go in the syncros were a real bear. Spent half the night looking for a spring that escaped. If I ever do another one of these I think I will order a parts kit for the syncro. Just in case. Funny thing was is I swept the floor with a magnet and nothing. Sat down on my shop stool and opened a beverage pondering the meaning of life and there it was stuck to the wall in plain sight. It was pretty slathered in vasoline so it never even hit the floor. Hopefully I can get it all buttoned up tonight and maybe even slap a coat of paint on it.
Old Jan 16, 2015 | 08:41 AM
  #35
dan123dbl's Avatar
Same thing happened to me with the ***** and springs. Dropped the ***** all over the shop floor and was searching for them for over an hour
Turns out the last one I couldn't find was in plain sight and noticed it when I wasn't looking for it any more.
Old Jan 16, 2015 | 03:13 PM
  #36
thrub's Avatar
There is an O-ring in the bearing kit that I got. I never took any O-rings out when I pulled it apart. Anyone know what this might be for?
Old Feb 5, 2015 | 07:24 PM
  #37
BILTIT's Avatar
I was wondering about the oring too.
What did you use to seal up the rear bearing cover and how did you factor in the thickness of it for the pre - Load?
I have my main shaft half stripped down, bit more to go to check the syncros and one more bearing to change.
Old Feb 11, 2015 | 07:25 AM
  #38
thrub's Avatar
I used a liquid flange sealant made by lock-tite. I did not factor the thickness of the sealant into my shim measurement. If the flange sealant added any thickness it would not have been measurable with the tools I have.
gwilming
Nov 3, 2011 07:08 AM
Mr. Plaine
May 23, 2008 12:37 AM
kanadiankaboy
Jan 13, 2008 12:30 AM
spunbearing
Apr 20, 2006 06:31 PM
Palmetto_kid
Oct 16, 2002 05:41 PM
