Getrag issue
Getrag issue
Well now my gutbag has a new problem. It shifts fine in town but once you hit the highway and get into 5th gear it doesn't like to come out of 5th. You have to come to a complete stop and fight with it and usually after the 6th or 7th try you can get it into 4th then from there it is fine again until you hit 5th. Any ideas what could be causing this?
Mine does the same thing and once when a mechanic had to move the truck he got it locked in 1st.
The cure of course is to get the shifter fixed but I'd just got in the habit of holding the shifter over until I'm sure it out of 5th before I try for 4th. It's a PITA at first but I got used to it. I'll get the gutbag overhauled someday but not yet.
Edwin
Originally Posted by BRUISER
I had the same problem.. found out that my tranny fluid was low.. I drained it then filed it up and added 1 extra quart no problems now
I filled it with 5 qts of Mobil 1 synthetic.Edwin
dan123dbl
Feb 13, 2015 05:47 PM
