getrag conversion questions.
Old May 22, 2008 | 05:54 AM
77machomopar's Avatar
Since Jasper Engine Rebuilders screwed me on my trans warranty. I am putting a getrag in. Heres my questions. I could find the answers to these in the search i have done. i know this topic has been covered alot. Thanks It is always appreciated
1. Can i use a clutch pedal assembly out of a gasser. If so i got one here.
2. Do i take off the heat exchanger on the side of the engine. Where does the outlets get plugged at?
3. Is the getrag driveshaft different from the 518 or 727 in a standard cab.
4. Will a gasser manual crossmember work or is that diesel specific.
Old May 22, 2008 | 06:56 AM
rbrettctd's Avatar
1. yes,
2. if you want to. i didnt yet but its in the plans.
3. yes, I got mine with the conversion transmission donor.
4. I think you can actually use the crossmember you have but Im not positive.
Old May 22, 2008 | 08:53 PM
bgilbert's Avatar
You'll have to do some fabbing to get the pedal from a gasser to work. It won't be 'bolt-up'. The crossmembers are different, you'll need to do some fabbing or get the diesel version.
Opus
Jul 5, 2011 05:19 PM
ridinlow333
Jan 8, 2008 01:57 PM
Fergavs
May 24, 2007 02:00 PM
efbeason
May 10, 2006 06:21 PM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
