Gear shift indicator?
Old Mar 18, 2008 | 09:20 AM
maxx250's Avatar
I know I asked this awhile back but I cant find the replies I got so here goes again,my indicator needle on my my gear shift is not moving when I put the truck in gear ,is this usually something completley broken or just something that has come loose?
Old Mar 18, 2008 | 10:24 AM
Free89W350's Avatar
Most of the time its just that something came off. If you take out your cluster bezel so that you can see the cluster itself and look just below the indicator there should be a small metal bare wire. This wire goes down and hooks onto a clip that attach's to the part of the column that moves with the shifter itself.
Hope this helps,
Old Mar 18, 2008 | 10:50 AM
maxx250's Avatar
Roger that dude,I was out there messing with it just now and got it back together.Thanks
Old Mar 18, 2008 | 01:17 PM
ofcmarc's Avatar
I've seen the cables break at the column before. PITA to fix.
vepchl
Aug 3, 2012 04:58 PM
kas83
Aug 2, 2009 09:23 AM
Aloha
Aug 6, 2005 11:52 AM
ViperSBT
13
Apr 8, 2005 10:29 AM
